Weight reduction for a streetdriven car
-full a/c including condensor
-full AIR system
-full egr system
-front swaybar
-stock front wheels (skinnies on the car)
-back seat, seatbelts
-jack, spare
But I have added weight...
-iron 6.0 block
-Moser 9" nodular center
-8 pt Alston chromoly cage
I was thinking of removing the heatshields, which ones should I keep?
This car will do 10,000 next year.
[ December 11, 2001: Message edited by: Pro Stock John ]
[ December 11, 2001: Message edited by: Pro Stock John ]</p>
How much did the a/c remove in lbs? I have soooo been wanting to do that but I live in Texas! Not a good idea for us folks <img src="gr_sad.gif" border="0">
-Jason
All removed oops...
40 lbs
Light weight seats
!cat back
Pass Air bag
Heater core
Rear seat belt spools
Carpet(or if you wanna keep the carpet)Just remove the under carpet isulation
<img src="gr_grin.gif" border="0">
<img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
I can't driving 700 miles sitting in a Kirkey race seat, is it me? <img src="gr_stretch.gif" border="0">
How about those heat shields, which ones should I keep?
You mentioned removoving the EGR..including the air pump? Front and rear bumper braces and styrofoam padding? How far do you want to go and still drive on the street?
Good Luck,
Chuck
Other items:
EGR/AIR/CRUISE is 16 pounds
You should try my carpet idea I was talking about earlier <img src="gr_stretch.gif" border="0"> that is 40 pounds at the track
ABS module if you dont have ABS functioning:not sure on the weight
Pass airbag: 15 pounds
front bumper support: 21 pounds
Kmember A-Arm combo: 44 pounds
manual madman rack: 25 pounds with power steering stuff removed
all heat sheilds and misc crap: about 5-10 pounds
rear bumper support: 19 pounds
foglights: 3 pounds
under dash panels: 4 pounds
That is 192 pounds not including the AC.
Plus there is other stuff I am forgetting I am sure <img src="gr_grin.gif" border="0"> I am contemplating doing some of those things <img src="gr_stretch.gif" border="0">
Cheers,
Chris
I would rather go 11.1's-11.2's@120 through the full exhaust and be light <img src="gr_grin.gif" border="0"> hahah
Cheers,
Chris
I am trying to be conservative here <img src="gr_stretch.gif" border="0"> hehehe!
Actually I have decided not to go with the K-Member A-arms route.
Just doing the lightweight hood (38), battery (20), carpet mod (40 at the track), EGR/AIR/CRUISE/foglights(19 pounds), pass and rear seat with belts (51 pounds) and some other minor stuff. That itself is worth 168 pounds. I can't afford to spend almost 700 bucks US for 44 pounds right now. What I mentioned above should make a noticeable difference especially where it is mostly off the front of the car. <img src="gr_grin.gif" border="0">
Cheers,
Chris
