Removal of clearcoat on glass?
Old Sep 7, 2008 | 12:29 PM
flyinZ's Avatar
Default Removal of clearcoat on glass?
I was just wondering, what the best way would be, to remove clearcoat over-spray, off of glass? I've got some on my front windshield.
Anybody?
Old Sep 7, 2008 | 12:57 PM
matthew S.'s Avatar
I use a razor blade. with water/or glass cleaner. Just kind of work it at an angle.
Old Sep 7, 2008 | 12:59 PM
chupr0kabra's Avatar
Try a claybar first. If that doesn't work, maybe a plastic scraper, or some 0000 steel wool with some white vinegar and distilled water.
-Mike
Old Sep 8, 2008 | 12:02 AM
LETHLS1's Avatar
steel wool and window cleaner.
Old Sep 8, 2008 | 08:36 AM
02gtp4now's Avatar
razor blade, or steel wool
Old Sep 8, 2008 | 10:11 AM
jorgez28's Avatar
you need really fine steel wool just polish the window with it.
Old Sep 8, 2008 | 10:29 AM
The Batman's Avatar
a new "unused" razor blade
Old Sep 8, 2008 | 06:18 PM
flyinZ's Avatar
Thanks guys!
Old Sep 9, 2008 | 01:17 PM
ArcticZ28's Avatar
-Mike
Exactly.
Old Sep 9, 2008 | 05:38 PM
LS1BLKSS's Avatar
Banned Village Idiot
you can try the clay bar... not sure what that would do but it removes over spary
Old Sep 9, 2008 | 05:41 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
I clean my glass with vinegar and 0000 steel wool every once in awhile...clean as.....glass.
Old Sep 10, 2008 | 08:38 AM
WhiteFormula98's Avatar
no lower than a 320 grit sanding block
Old Sep 10, 2008 | 09:07 AM
firehawk#682's Avatar
clay bar will work just fine.
Old Sep 10, 2008 | 11:55 AM
samson_420's Avatar
I would say a razor blade will work fine.
But, what about a rash solvent, like paint thinner? Will it damage the glass? Maybe thin it down a bit, depending on hom much paint is on the actual glass.
Old Sep 10, 2008 | 12:10 PM
ArcticZ28's Avatar
Paint thinner actually won't do anything once the paint has set. Often times people actually use paint thinner to remove bugs and tar. Although it is not advised and can severely harm your trim, it can work in certain situations.
