Old 05-03-2016, 01:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
camaro headlight removal
Old 09-11-2008, 04:32 PM
PhantomR/T's Avatar
Default camaro headlight removal
I searched for a while but I couldnt find any links for this. I know its probably very easy to do, but I like to know what I'm doing before I do anything. Do you need to take that whole bracket out, or do the headlighs come out with the brackets in place still? Thank you in advance!
Old 09-11-2008, 04:36 PM
homerunhtr21's Avatar
2 10mm bolts per headlight is all you need to remove. Very simple.
Old 09-13-2008, 03:52 AM
litemup02's Avatar
If i remember correctly...Once the bolts are removed you have to grab the headlight and slide it over to pull it out. Little plastic tabs on the light that go in the bracket and lock in.
Old 09-13-2008, 12:11 PM
PhantomR/T's Avatar
yup. Was really easy to do, but now the fun part is getting them adjusted proparly in the daylight. haha
Old 09-13-2008, 12:20 PM
litemup02's Avatar
Just pull it up to a garage or a wall with them on. Then you can adjust them level atleast and go fom there
Old 09-13-2008, 12:27 PM
99ssleeper's Avatar
there is one 10mm bolt on each headlight that you remove. it is right under the black brace on top of the headlight that goes from the core support to the back of the headlight. take that bolt out, slide the headlight towards the center of the car to unhook it from the bracket. take your time and look at it, its not difficult.
Old 09-13-2008, 05:03 PM
nifty97z's Avatar
Seems he already had them out and reinstalled
Quick Reply: camaro headlight removal
