No 2-3 shift at WOT?!?!?!
so looks like its coming out for some work. Line pressure can only be measured at the port manually on the side of the trans/ The number is low for WOT though even for that area but its based on the current being fed to the PCS not actual. Your PCM is commanding the line pressure down for some reason if its not hitting the 90 setting you made.
FYI actual line pressure runs from 60 to 230 PSI.
The 60e has no way to measure pressure rather the PCM calculates what it should be based on the amount of current it sends to the pcs
1-The shift is being commanded and the solenoid is failing to vent (BAD shift solenoid).
2-The shift is being commanded and the shift solenoid is working properly and the clutch set is not holding (slipping).
3-If a shift kit was installed there are two small holes in the plate that for some reason some people enlarge these holes if they are made to large it will prevent high line pressure shifts from 2-3 (solenoid flooding)
4-The line pressure itself is way to high this also can like above holes cause to much fluid to be fed to the solenoids causing solenoid flooding which can also cause a no wot 2-3 shift at wot.(solenoid)
Just some ideas
