transmission mount question
Old Dec 7, 2008 | 03:17 PM
jawsgt's Avatar
Default transmission mount question
i have a 94 formula im going to be installing either a th350 or th400. is the mount the same and can i use the stock crossmember? i bought the car with no engine or trans and im installing a small block 350 out of an older vette. this car is goin to see the track alot so wut converter/gear combo is good? im pretty new to racing automatic cars every car i used to race has been a manual and when i picked this car up i wanted to mainly race it. It will have a cam/nitrous set up also
Old Dec 7, 2008 | 04:33 PM
sz282's Avatar
You'll need to get a conversion crossmember or modify the stock one bmr makes them as do others. If it's a mostly track car 3.73s or even 4.10s are good for an auto. Check out the FAQ in this section for a write up.
