What trans for my car?
Old Dec 7, 2008 | 04:48 PM
Ryans_pewter_ss's Avatar
Default What trans for my car?
I'm wanting to go auto. I can't be consistant with the m6, The car is an 02 SS, 6.0 iron, l92 heads, gmpp intake, 228 232 600/630 112lsa. running 150 wet carb style plate kit. Has a Moser 12bolt with 4.10's but i can change to whatever. Car is full weight, 3400lbs. Not a dd and not a full racer, just something to play with. What trans do ya'll recommend and what stall? I have a buddy with a built th350 with trans brake that he will sell me.
Old Dec 7, 2008 | 04:54 PM
TXZ28LS1's Avatar
for your setup i think a properly built 4L60E from FLT, PERFORMABUILT, or circle D would help you out. just make sure you get your tranny built right the first time. also, i think a good all around stall is atleast a 3500 stall.
Old Dec 7, 2008 | 04:58 PM
What about a th350 or 400 with brake? I don't really wanna go with the elec. trans. there a little more than i wanna spend and alot harder around here to find people to work on them
Old Dec 7, 2008 | 07:30 PM
FLT's Avatar
FLT
We work on them all the time. Give us a call. Vince
Old Dec 7, 2008 | 07:52 PM
I'll do it. Thanks!!
Old Dec 7, 2008 | 09:19 PM
heymoej's Avatar
they make a trans brake for the 4l60e tooooooo.
FLT makes a great product,ask me how i know.......good luck!
Old Dec 7, 2008 | 09:44 PM
dnkynrbk's Avatar
Call Frank at Peformabuilt lv2 over 300 passes w nitrous and still going strong.
Old Dec 7, 2008 | 10:01 PM
performabuilt's Avatar
LS1Tech Sponsor
We do carry the 400 and 400 with rmvb and transbrake
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 8, 2008 | 06:47 AM
Whats best for my setup? Usually only run 1/8th. Glide,th350, or th400??
Old Dec 8, 2008 | 09:11 AM
LS1Tech Sponsor
I would go 400
__________________
Call 888-744-6542
Old Dec 8, 2008 | 09:50 AM
TT632's Avatar
With your set up and bottle, and the right convertor you don't need 4:10s. Buddy just toasted his fully built 4L60E from a sponsor here with his full weight L92 headed nitrous car. Not the builders fault, since he knew at that power level it was time to upgrade to a 400 anyway.
Old Dec 8, 2008 | 07:15 PM
I would change the gear also, maybe 3:73 or something like that
