Whats wrong with vigilant converter ?!!!
i told hem that its a daily driving car then i specified all the mods i had and the power band of my cam and the weight of my car.
when i installed the converter i lost my tranny 2 times in one week
due an over heat issue (( i had a tranny cooler )) which we discovered in the second time when we attached the tick2 and scan it for the problemthen i dropped this converter and went back to the stock one .
so my advice for you to buy directly from the company not from a sponsor.
You bought a VIG converter from a sponsor that was not VIG and it was bad and its the sponsors fault?
So if you had bought the same converter directly from Precision and it was bad that would be different?
I don't understand.
Now if your saying the converter was the wrong stall speed or something and that was th cause of the trans failure and overheating I will say thats not possible.
And what does all this have to do with buyng from a sponsor verse the manufacturer?
And when you say it burned your tranny twice in one week. Do you mean te transmission failed twice in one week and if so your builder should have been able to make the determination of the cause the first time,
And no if the converter was the wrong stall speed etc it would not burn up the transmission.
Its impossible to say what happened here but I will say blaming thunder racing would certainly not be the answer. If indeed it was a bad converter that would fall on the company that made it, However again you have not supplied enough information to determine what actually happened.
when i reached to the shop they scan it using tick2 and the problem was transmission over heat then they told me its a converter problem and you should go back to the stock one.
when they opened the tranny they found every thing burned i saw the color of all metal parts in side tranny turend black. so i had to buy a new trany and go back to the stock converter.
now I'm not blaming thunder racing neither VIG i just want to know what was the problem because i want to order a new converter what do all think ?
Chris
