LS1 to TH400 Converters???
Old Dec 13, 2008 | 03:26 PM
cabech984's Avatar
Default LS1 to TH400 Converters???
Ive been looking around for a Torque Converter for my TH400 that can adapt to the stock LS1 Flywheel. Are there any companies that do this? Im looking for a 4400 stall TC. Links would be sweet!
Thanks,
Chris
Old Dec 13, 2008 | 04:56 PM
N.Etheridge's Avatar
yes yank and a few more have them. I know speed inc sells them you can also use a standard 350/400 converter.
Old Dec 13, 2008 | 05:49 PM
cabech984's Avatar
To use a standard 400 converter, dont you have to buy the TCI(or equivalant) flywheel or spacers??
I have a Fuddle Converter for my 400 but it stalled 3200 behind a Turbo Buick V6 and am looking for something in the 4000-4400 stall range behind the LS1 Im building
Old Dec 13, 2008 | 06:00 PM
blockheadnic's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 13, 2008 | 06:35 PM
WYATT318MOPAR's Avatar
I am running an old school converter in my 400 along with the hughes adapter and I had to get some indexing converter washers from jegs to get mine to space out right and properly engage the pump in the tranny. Heres the part JEGS #555-82505
Old Dec 13, 2008 | 06:55 PM
SSPerformance's Avatar
all you need is a 1998 flywheel from a ls1 car.
Old Dec 13, 2008 | 07:26 PM
What makes those special?
Old Dec 13, 2008 | 07:30 PM
correct bolt pattern for a LS1 th400 converter
Old Dec 13, 2008 | 07:41 PM
cabech984's Avatar
Looks like most 5.3L and 6.0L Flywheels are too. can anybody confirm this?
Old Dec 14, 2008 | 10:28 AM
I know most 6.0 seem to be because they usually have 4l80's behind them. For the 5.3 I am not sure on that, I am running a 98 flywheel and still had to shim the converter back so I don't think its perfect. Hughes actually says their adapter is made to run with just their flywheel on the website and it has welded on tabs to space it out.
Old Dec 14, 2008 | 06:21 PM
cabech984's Avatar
My 6.0L was in front of a 4L60/65E.
Old Dec 15, 2008 | 07:09 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
We make direct bolt in converters for the LS1 and a 400 with a factory flexplate that has the correct bolt circle and pilot.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Dec 16, 2008 | 02:17 PM
ForcedInduction's Avatar
If you have a 6 bolt TH400 converter you need a stock 6.0 flexplate that had a 4l80 behind it. And the spacer that goes between the crank and that flexplate. Bolts right up. If you have a 3 bolt converter, you and use the flexplate and space i mentioned, just need to oblong 3 holes just a little bit.
Old Dec 16, 2008 | 04:05 PM
I have a 4L80 flywheel, spacer and the longer bolts to install it. My question is in order to run it do you have to run a truck starter or will my f-body one work?
Old Dec 16, 2008 | 04:27 PM
Your Fbody starter should work fine. When I swapped flexplates on my truck I went from a dished to flat with spacer and it didnt effect my starter. I never really thought about it, until you said something. ahah
Old Dec 18, 2008 | 04:37 PM
cabech984's Avatar
Well thanks for all the advice/opinions guys.
I have a 3200 stall converter for my TH400. The stall speed was rated that behind a 3.8L Turbo V6 Buick engine that propelled my Firebird to 12.20@113mph.
What do you guys think this converter may stall behind a H/C/I 6.0L?? Any advice??
Old Aug 11, 2009 | 11:08 AM
wajouba's Avatar
Hey WYATT318MOPAR... what does the TH400 do with your 4.10? Cause my Nissan has a 4.11 and I'm installing a TH400 on the LS1... I wana know gas mileage, and speed rpms through out the gears... what are they..?
Thanks bro...
(btw: I still don't get what is needed in the end, I have a 98 LS1 from an F-body, what do I need exactly for it to bolt on to my LS1? All I know is that I need the spacer from Summit, what else have we came on to agree that is needed with the LS1 98?)
Old Aug 15, 2009 | 08:35 AM
wajouba's Avatar
I went to the place where he had the TH400, I saw it, checked it out... the question I wana ask... is that he offered to give me the Torque Converter with it saying that I will need to use it, plus he gave me a Flywheel that has 2 hole areas that will make the th400 fit, does he know what hes talking about? and will it work? shim in everyone please, I don't want to buy something that would backfire later...
Old Aug 15, 2009 | 09:56 AM
Yank's Avatar
Here is a link to the LS converters to TH350 or TH400
http://www.converter.cc/converters/race/GM/1/
Call for sale pricing
Old Aug 15, 2009 | 10:24 AM
wajouba's Avatar
Ouch... 845$ kinda high for me now... sorry my salary is 400$ lol... I just graduated and am getting experiance so no money for now... hehe...
Alternative...?
Where is the space going to happen? (wheres the gap?)
If I use TH400 --- Torque (th400) --- Flywheel/Flexplate (98 or old one that has 2 type bolts) --- spacer (from summit)
Where will the space be? the gap? between torque converter and flexplate? and whats another alternative to the Yank Converter?
