Problem with converter?
Old Dec 15, 2008 | 03:42 PM
2kta--89formula's Avatar
Default Problem with converter?
I just noticed something was off with my car today. Accelerating from a stop at 1/2 throttle or so (RPM's under 3200) the car upshifts to second and seems to struggle maybe even bog at around 2600-3000 rpms. When the car gets to 3200 I can feel something unlock (or the converter engaging?) and then the car accelerates normally. This only occurs on part throttle roughly 50/60%. Full throttle is ok, and normal driving is ok. The problem is difficult to duplicate but seems to be brought on by accelerating 1/2 throttle through first, then in second when the rpms are at 2600-3000 if I apply more throttle it seems to struggle and almost bog. When the RPM's get to 3200 it stops and accelerates normally the rest of the way. Is this a tuning, converter, valve body, or trans issue?
Thanks!
Old Dec 15, 2008 | 06:46 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
I noticed that you are local to me and if you would like me to drive it and look at it i will.I can put the scanner on it as well.I am on the north side of deland.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
