4L603 1st and 2nd slipping
Old Dec 16, 2008 | 03:20 PM
F3RR3T's Avatar
Default 4L603 1st and 2nd slipping
i just got a 94 lt1 z28 with 90,000 miles for $1500.00. seen here https://ls1tech.com/forums/introduct...l#post10658427
it has a 4l603 (i believe) and first and second are slipping (i was aware of the issue before buying the car)
the fluid has a slight pungent burnt smell to it. and is darker than the used fluid in my 94 pickup with 10,000 miles on it.
im just trying to get possibility's before i tear into it
Old Dec 16, 2008 | 03:39 PM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like its just burnt up rebuild or replacement time
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 16, 2008 | 03:55 PM
F3RR3T's Avatar
whats average cost on a rebuild kit
Old Dec 16, 2008 | 08:52 PM
F3RR3T's Avatar
i just got quoted 850 to rebuild it if i pull the trans is it just me or is that a bit steep
Old Dec 16, 2008 | 09:24 PM
LS1Tech Sponsor
For a stock bench build depending on where you are at thats reasonable I would think low in some places a little high in others , Just depends
__________________
Call 888-744-6542
Old Dec 16, 2008 | 10:08 PM
F3RR3T's Avatar
same place only charge 150 to rebuild a turbo 350 i supplied the parts
Old Dec 16, 2008 | 10:19 PM
IronOutlaw's Avatar
I was quoted 1200 for a rebuild if i pull mine so that is a pretty good deal.
Old Dec 16, 2008 | 10:57 PM
01ssreda4's Avatar
1400 i was told locally and good to 400hp. HA.
