Pulling my hair out.
Everything went smooth until it was time to pull out the flywheel-converter bolts. We still can't get them out. Not to mention one is stripped. We ended up getting one out by heating it with a torch and then getting it out.
We could literally almost hang on the ratchet(didn't) and they wouldnt even budge. They aren't loctited in because we did get one out. Why are they so damn tight?
Also is there anyway we can get the stripped one out. We have tried the torch and vise grips. I don't want to try an air hammer because i would rather not have to buy a new flywheel. Anyhow ill be going to pick up some new bolts at a dealership tomarow but whatever suggestions you have feel free to shoot them to me.
I'm just so frusterated at this point. I could hardly stand to look at my car when we left the shop. I dont understand why they are so tight. He did his stall at about 108k miles in his T/A and he said his came out rather easily.
Anyway ill end my rant.
Thanks for the offer none the less.
We also got pretty easy access to them they just honestly won't budge. We have one out. One is not stripped. And one is stripped. How can we get the stripped one out without screwing up my flywheel?
Anyone else have any other ideas?
Crossing mine as well. Good Luck.
His bolts were different...they had the allen grooves on the inside and had a regular bolt head on the outside. I think they were 9/16", but don't quote me on that. The bolts I put back in were the style you described. They were original bolts out of my car.
Did you weld the nut around the bolt or did you fill in the bolt when you welded it(what ill be doing). I figure if i do it that way the weld will be stronger and wont even touch the flexplate but it will heat the bolt up enough to loosen it up as well.
either way id go ahead and replace the flexplate, they arent too much.
