Grinding
Old Dec 21, 2008 | 09:36 PM
4THGENCAMAROFAN's Avatar
Default Grinding
Car is a 95 3800(not sure which trany the automatic was). Intermittent grining. Sometimes when you drive the car it's perfectly fine other times it constantly grinds...even in neutral.
What's going on here guys???? Please don't tell me I need a new trans. Also has an rpm flair on the 2 to 3 shift.
Old Dec 22, 2008 | 12:47 AM
performabuilt's Avatar
LS1Tech Sponsor
Well I would try the manual section first, But would be hard to diagnosis with out hearing and feeling it
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 22, 2008 | 08:33 PM
Why the manual section????
Old Dec 22, 2008 | 08:34 PM
Ok a new addition to the problem. My car will accelerate when you push the pedal in neutral. What in the f*cking hell??????????????? My car is f*ckin weird.
Old Dec 23, 2008 | 01:25 AM
BobDoLe's Avatar
if the car is accelerating in neutral and its not the transmission, it must be possessed...
so i'd take it to a tranny shop or exorcist - pick your poison.
Old Dec 23, 2008 | 01:34 AM
Camaro396's Avatar
Your post is all sorts of confusing. Do you have a Auto or a Manual? One section you say Auto, then you mention a clutch???????????
Old Dec 23, 2008 | 01:35 AM
My dad said that it's normal for auto cars to do that when it's really cold like it is here.
Old Dec 23, 2008 | 06:35 AM
twitchtwice's Avatar
i think he's young and isnt sure how a transmission works.
Old Dec 23, 2008 | 11:02 AM
You're right....absolutely cluelss as how an automatic transmission works.
Old Dec 23, 2008 | 11:07 AM
The car is an automatic...I mention clutch because automatics have clutches too, not just manuals.
I'm thinking the clutch might be bad becuase it has an RPM flair on the 2-3 shift when driven hard, indicating that the clutch could be worn out and not engaging into third gear quick enough causing the rpms to flair up.
Old Dec 23, 2008 | 12:28 PM
Camaro396's Avatar
I believe your confused on how an automatic transmission works. They do not have "a clutch" they have clutch packs, but I think your confused on how they work.
Old Dec 23, 2008 | 12:46 PM
well that's what i was reffering to was the clutch packs. I just said clutch for short.
Old Dec 23, 2008 | 07:15 PM
Any other info guys???? I'm absolutely clueless on auto transmission(don't know a lot about manuals either).
