New Sponsor, Trinity Transmission
what kind of power would your 6L80 build be able to hold and what kind of price bracket would it be?
e.g. >700 rwtq ?? >1000 rwhp ??
and can you elaborate on the standalone controller setup? e.g. VSS and RPM and 12V and it shifts? paddle-shifters? etc?
_
The controller is used in other applications at this time and it does simulate VSS so you can use a digital speedometer. It has paddle shift capability as well. It does work with the ZF5hp and last I heard they had it working with the zf 6hp. Check with the link below to inquire about the zf models.
As for affordability, that is a big challenge considering the SPO price for a 6l80e it around 2500 stock plus a core charge. Then you have to add a modified controls package for around another 1500 at least. This is just a stock 6l80e. Add a TC for another 1000-1500 and you have a fairly expensive conversion.
http://www.powertraincontrolsolution...content-4.html
Greg
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
