2004 & up tailshaft bushings
since i was replacing all the bushings in my trans, i figured i would do the tailshaft one also(looked like the direct clutch "bonded" piston had a seal blow out)
the bushing looked good, but since i had the new one i pop'ed it out, and found the new one you could install by hand-it was the copper looking one, where the orig was silver looking-i called transtar, and they showed it was changed to a larger one, and its not available!!!
i prob could locktite this one and stake it-would that work?
sure getting a lesson doing my first 4l80e, actually kind of enjoying doing it,
found a good book to go along with the atsg book-also using the transgo split turbine seals, so i dont need that seal sizer tool
Closed ex-Sponsor Account
Bushings are exposed such severe loading conditions throughout the life of the transmission. It is not worth the risk if the fit is questionable.
I put a Sonnax pressure limiting valve in mine to be sure the line pressure doesn't blow anything else up.
I hope you put one in your build. Other companies have them. I think it's standard in the transgo kit.
