trans ID tag
Old Jan 3, 2009 | 06:56 PM
blockheadnic's Avatar
Default trans ID tag
I am curious what my Th400 came out of.
The tag says 455 CA-67-51291
Old Jan 4, 2009 | 10:48 AM
tptransmission's Avatar
Closed ex-Sponsor Account
I'll take a stab at it. It appears to be from a 1967 chevy with big block engine. Although the "455" does not match any Julian date.
Old Jan 4, 2009 | 01:24 PM
So would it be a good choice to rebuild. Its a short tail shaft with slip yoke.
So 455 is a date not a engine?
I was told it came out of a station wagon but he wasnt 100%
Old Jan 4, 2009 | 03:30 PM
FLT's Avatar
FLT
Just about any th400 would be a good choice to build. The obvious thing to look at is that the unit has a good case with good internals. In most cases you will want to make sure that you have a sprag style direct drum when building the unit and also an output shaft that uses a slip yoke. Other than that they are all pretty much a good candidate. Vince
Old Jan 4, 2009 | 05:58 PM
Well i was told that mine may have a planetary with 4 gears vs 3. if you understand what i mean.
I dont know about the sprag. got any pics to tell the difference.
I have two 400s and both look good.
Old Jan 4, 2009 | 08:50 PM
FLT's Avatar
FLT
I have never seen a 400 with a 3 pinion gear planet. I will have to look through my photo's to see if I have a picture of a sprag style drum vs the spring and roller style.
Old Jan 4, 2009 | 09:04 PM
There has not been a three pinion gearset in a 400. Below is a nice overview of the difference from another LS1 Tech user.
http://www.hotrodders.com/forum/th40...cs-145318.html
Old Jan 4, 2009 | 09:36 PM
Thanks for the link should help with my questions. Hope to start my rebuild in the next couple weeks, and hope to have it running before spring.
Old Jan 4, 2009 | 09:48 PM
Thanks and feel free to drop an email if you need any more assistance.
