Shifting problem
Old Jan 3, 2009 | 09:58 PM
zrultima's Avatar
Default Shifting problem
I have a problem when shifting i just want to know what it is. Started happening after i finish racing. Now the problem is it not shifting like it use to from 1st to 2nd it takes it up to 2000 - 2500 rpm so it can shift to 2nd. Before it use to shift at 1500 rom please help me
Old Jan 3, 2009 | 10:24 PM
blockheadnic's Avatar
Check fluid level, color, smell.
Old Jan 3, 2009 | 10:27 PM
bluchev's Avatar
what vehicle/year?
Old Jan 3, 2009 | 10:34 PM
zrultima's Avatar
ls1 01
Old Jan 4, 2009 | 01:36 AM
zrultima's Avatar
camaro ls1 Z28 01
Old Jan 4, 2009 | 04:13 AM
Camaro Junky's Avatar
camaro ls1 Z28 01
My 07 suburbo was taken in because of the same thing. Would use a lot more RPM to shift. Sprags were fucked and shared some metal with the whole trany.
Old Jan 4, 2009 | 01:55 PM
zrultima's Avatar
can really understand what u typed? it messed up a spring? what spring exactly
Old Jan 4, 2009 | 02:15 PM
performabuilt's Avatar
LS1Tech Sponsor
Is the speedo working ? any codes? Are you sure its shifting to second and not 1-3 ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 4, 2009 | 03:31 PM
zrultima's Avatar
yeah the speedo working fine what its doing it shift till like 2000 rom when in 1st after 1st its fine
Old Jan 4, 2009 | 03:47 PM
LS1Tech Sponsor
Try manually shifting from 1-2 and just hold there does it shift to second at any rpm ?
__________________
Call 888-744-6542
Old Jan 4, 2009 | 04:18 PM
FLT's Avatar
FLT
Any codes?
Old Jan 4, 2009 | 05:27 PM
zrultima's Avatar
It will shift it just shift at high rpm not at the normal when im crusing but it only happens during 1st and 2nd that it the others work just fine
zrultima's Avatar
no codes just p1133 and p1153 since i have long tubes
Old Jan 4, 2009 | 05:29 PM
zrultima's Avatar
best way to explain it is it acts like it has no overdrive like its just in D
Old Jan 5, 2009 | 02:30 PM
zrultima's Avatar
Anyone have a clue??!?!?!? as for my tranny fluid its not at optimal level so imma try that and see if its the one causing the problem
Old Jan 5, 2009 | 02:38 PM
LS1Tech Sponsor
Well the 4L60E shift points are completely at the mercy of the PCM I would top the fluid off however with th exception that its missing 2nd and going right to third you will need to get it on a scanner to tryand figure out whats going on. The trans has nn mind of its own
__________________
Call 888-744-6542
Old Jan 5, 2009 | 06:32 PM
zrultima's Avatar
no if it would shift to 3rd then my rpm would go done like crazy its going down but it takes a long time to shift to 2nd like it would shift on overdrive at about 25 mph
Old Jan 5, 2009 | 07:03 PM
LS1Tech Sponsor
But did you try what I said manual shifting 1-2 then leaving it there to see what happens ?
__________________
Call 888-744-6542
Old Jan 5, 2009 | 11:50 PM
zrultima's Avatar
yes i did it will shift but not exactly when i shift it
Old Jan 6, 2009 | 01:57 PM
zrultima's Avatar
well just found out i have no 2nd gear man life is really shitting on me now
