Converter slip or gear?
Old Jan 6, 2009 | 07:00 PM
jetlag's Avatar
Default Converter slip or gear?
According to http://www.f-body.org/gears/, with 3.73s gears and a 6100rpm shift in 3rd gear I should have a top speed of 125mph.
Why is it my car stops at 120? It feels like it tops out. Is that just the converter slipping on the nitrous?
I only gained 6mph on the topend from a 100 shot.
Old Jan 6, 2009 | 07:19 PM
performabuilt's Avatar
LS1Tech Sponsor
Sounds about right figure on converter slip and variance on tire sizes . You might get a little more if you locked the converter at the top but i doubt the whole 5 mph
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 6, 2009 | 09:03 PM
jimmyblue's Avatar
Moderator
I would expect you to be looking at about 3-5% slip with
that converter. Which might account for the error, but a
slipping converter will still accelerate you some (not "hit a
wall"); more like a rubber band pulling less and less as MPH
catches up with RPM.
Old Jan 6, 2009 | 09:16 PM
jetlag's Avatar
Well..not sure if this math is right...but.... 125mph (according to the calculator) x 4% slip = 5....so that would be my 120mph top speed..
Maybe I'll just add...MO POWAH ....and go to 3.50 gears..
