trans not getting fluid?
Old Jan 9, 2009 | 12:18 PM
johnLs1camaro's Avatar
Originally Posted by 9000th01ss
Thats what I'm trying to get an answer about.
If I pulled out a converter with a broken hub, I'd take the pump apart first thing.
It sounds like that never happened.
well man i had the tranny gone through, and i watched the guy pull it out, is there a way to test it? im no trans. mechanic so idk what to have looked for. all i know is he didnt say anything about.
i took the tranny out today, and im taking it to a shop to be checked out. no luck with un doing the lines.
Old Jan 9, 2009 | 05:11 PM
9000th01ss's Avatar
Does this guy know you broke a converter hub in that transmission?
The converter hub is what turns the pump.
Break a hub--break a pump (usually)
You're lucky if the hub on the new converter didn't get messed up too.
