Weird clinking sound after 4l80E install
Thanks
Rob
Is the yoke counterbored?
Does the output shaft have a shoulder or is it splined all the way.
It may or may not be the problem, but I wouldn't run a DS so short.
Even at 2 1/2" in it's just past the bushing. And if it's a non counterbored yoke on a tailshaft with a shoulder, it's probably binding up when the rear suspension compresses.
This is obviously all speculation given the fact I can't see it, and there aren't many details to go on.
The output shaft does have a shoulder with O ring, and im using a counter bored yoke with it... also when it does the cliking sound the car kind of bucks like if the yoke is not engaging all the way..... like i said in the original post, when its under load, it all goes away.
If the yoke was slipping, the car would eventually quit moving within a few miles. If it were the case I doubt there would ever be enough spline engaged to hold a run under any kind of load.
You could always pull it out and check. But I think it's time to look for other problems.
I didn’t think that there could be that many possibilities causing my problem. So im thinking my first course of action will be to pull the DS tomorrow, and get another one the correct length., then work from there. If anything else comes to mind, let me know.
Thanks for everybody’s help, and ill keep you posted.
