lockup on stalled TH400?
Old Jan 10, 2009 | 06:24 PM
BobDoLe's Avatar
Default lockup on stalled TH400?
i tried searching a bit, but couldn't find exactly what we were looking for.
a buddy of mine has a 60's el camino with a 454ci motor (no hood), TH400 with huge stall, ford 9inch.
he's trying to make it just a little more streetable, but is trying to explore options before going with a 700r4.
i read somewhere where you could rig up a solenoid, get a torque converter with lockup and activate it with a switch on the dash.
how inexpensively can this be done? can anyone recommend a good unit?
Old Jan 10, 2009 | 07:58 PM
tptransmission's Avatar
Closed ex-Sponsor Account
I believe you are referring to the vairable pitch converter that was in the 64-66 roughly.
Old Jan 10, 2009 | 08:01 PM
FLT's Avatar
FLT
PI had a kit to do this years ago and the converter had a converter clutch. Give them a call to see if it is still available.
Old Jan 10, 2009 | 08:08 PM
PI? do you have that link?
Old Jan 10, 2009 | 08:18 PM
JFM-jr's Avatar
I believe he is referring to Precision Industries
http://www.converter.com/
Old Jan 10, 2009 | 09:14 PM
TurboAv's Avatar
Yank also did a lockup TH400 transmission and converter a few years back.
Old Jan 10, 2009 | 09:18 PM
forcd ind's Avatar
im running the switch pitch 400 in mine
i had heard the guy that built the 400's with the clutch converter wasnt building them, but would repair them, but not 100% sure
now back in the day, i had a clutch turo 400, you cut the bellhousing off, used a stick bellhousing, clutch, diff pump, etc-talk about a brutal shift
and forget the 700r, unless you drive it slow to the store
Old Jan 10, 2009 | 09:22 PM
Thanks for the reply we are all continuously learning. I did not understand why someone would want to lock a 400 when it was not really accepted in a T350
Old Jan 10, 2009 | 11:23 PM
TurboAv's Avatar
Because some of us don't want to spend $5g's on a 4L80E setup.
Old Jan 11, 2009 | 01:01 AM
BobDoLe's Avatar
thanks, i'll contact PI and see what they can do.
