Need a ghetto way to lock flywheel
Old Jan 20, 2009 | 06:54 PM
1998Z28LOADED's Avatar
Default Need a ghetto way to lock flywheel
What's the best way to lock the flywheel w/o buying the tool?
Old Jan 20, 2009 | 07:01 PM
Phil99vette's Avatar
7 Second Club
If you have a buddy with a mig welder, you can take a piece of 36" x 1" x 1/4" steel flat stock and weld 2 - 1/2" x 3" dowels on the end to fit into the damper. The dowels will key into the front damper.
Old Jan 20, 2009 | 07:09 PM
That would be nice but I was hoping for something more simple.
Old Jan 20, 2009 | 07:11 PM
jsteele90's Avatar
jam a screwdriver in there
Old Jan 20, 2009 | 07:24 PM
ROCNDAV's Avatar
+1
I havent tried this on an LS1, but I've done it on many other cars.
Old Jan 20, 2009 | 08:14 PM
BadBandit69's Avatar
a buddy with a prybar on the teeth....work for me
Old Jan 20, 2009 | 08:15 PM
xBROKEx's Avatar
same here
Old Jan 20, 2009 | 08:16 PM
tillery's Avatar
Are you Replacing your damper?
Old Jan 20, 2009 | 08:18 PM
fast377's Avatar
Bingo!
Old Jan 20, 2009 | 09:43 PM
I think I'll try the buddy with a prybar method. My origional idea was to do the screw driver but it broke a soon as I tried to break the crankbolt loose.
Old Jan 20, 2009 | 10:12 PM
Super Speed's Avatar
Prybar should work
Old Jan 20, 2009 | 10:14 PM
RyderTA's Avatar
I used a thick craftsman screwdriver to hold mine in place, worked great.
Old Jan 20, 2009 | 11:00 PM
Damian's Avatar
LSX Mechanic
A very thick screw driver will work, or pry bar. Easiest way to do this is pop open the peek hole, get the prying tool of your choice, stick it in one of the holes in the flexplate, slowly turn the crank bolt, let the tool it pry itself against the trans housing until it's sitting in place, and then yank away on the bolt.
Done that for years and works fine. I'm too much of a cheap *** to buy the "flywheel holding tool". My pry bars work just fine and they're already paid for
Old Jan 20, 2009 | 11:47 PM
WestSide's Avatar
I jammed a screwdriver between some teeth while my buddy did the work. Real easy.
Old Jan 21, 2009 | 01:00 AM
jetlag's Avatar
1. get a waterhose
2. turn it on
3. put in throttle body
4. start car
4 easy and ghetto steps to lock the flexplate.
Old Jan 21, 2009 | 02:54 AM
00Formula00's Avatar
Is this to get the crank bolt off? If so, I just use an impact gun... But to put the bolt back on, screwdriver
Old Jan 21, 2009 | 08:13 AM
9000th01ss's Avatar
Ghetto? Have a buddy hold the breaker bar, you turn the key. Make sure it has room to swing before it hits something, otherwise the car won't start and you won't have enough torque to break it loose.
Old Jan 21, 2009 | 09:16 AM
Lmao at 2 of the last 3.
... And to the other guy my car is A4
Old Jan 21, 2009 | 10:42 AM
1sick'98WS6's Avatar
craftsman makes an adjustable prybar, Also remember there are tapped holes in the back of the cylinder heads that you can slightly thread a bolt into to hold the prybar/screwdriver/ghetto tool in place while you remove the bolt
Old Jan 21, 2009 | 08:08 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
Originally Posted by jetlag
1. get a waterhose
2. turn it on
4. start car
