4l80e installed, then test drove it
Old Jan 24, 2009 | 06:21 AM
forcd ind's Avatar
they had replacement springs for the boost valve, a washer i guess as a spacer for the larger spring, a spacer for the pres valve, depending on which valve you have(cant remember which i had)
they also had you enlarge a hole behind the pump seal, to prevent seal blowout?, and drill thru a passage in the pump stator(.042-.055)-also install a larger snap ring(last one in trans), but the newer trans already have that
also changed springs in the direct clutch pp
Old Jan 24, 2009 | 08:54 AM
tptransmission's Avatar
Closed ex-Sponsor Account
That should not be a problem with our kit.
