TH400 driveline question
Old Jan 23, 2009 | 08:00 PM
gsxr1k2's Avatar
Default TH400 driveline question
How much of the transmission side of the driveline has to be in the tranny. My driveline is only long enough to get a little under half of it in the tranny? It doesn't vibrate or leak and seems to drive fine but just wanted to be sure.
Old Jan 23, 2009 | 09:50 PM
tptransmission's Avatar
Closed ex-Sponsor Account
It all depends on the length of the yoke and also your rear suspension travel. In most cars such as yours, it should be fine if have a minumim appr. 2 inches of spline engagement into the transmission.
Old Jan 23, 2009 | 09:54 PM
gsxr1k2's Avatar
Ya I'd say theres at least two inches so cool, thanks!
Old Jan 23, 2009 | 09:58 PM
You should be fine. A quick check is if you lift the car with axle full extended you don't want the yoke to come out to far.
Old Jan 24, 2009 | 11:05 AM
gsxr1k2's Avatar
K, will do
