No overdrive and ses light?
Old Jan 25, 2009 | 09:00 PM
iosigma's Avatar
Default No overdrive and ses light?
Tonight i was leaving a friends house...started up my ca..started down the road....almost immediately the ses light came on...engine sounded fine but the car would engage into overdrive at speed...most of the time you can tell by (engine noise, tach reading, and so forth) when the car changes gears...it was doing nothning out of the ordinary before and i wasn't running the car hard or anything, just ordinary street driving. Any suggestions what might be wrong? Maybe a vacuum hose some where loose or something? BTW sorry if this thread is in the wrong part of the forum in advance.
Old Jan 25, 2009 | 09:37 PM
performabuilt's Avatar
LS1Tech Sponsor
First thing to do is get it scaned and find out what that code is it will hold the answer and no its not likely a vaccume hose
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 25, 2009 | 09:40 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Check the codes it may be an 1870 code.
Old Jan 26, 2009 | 03:07 AM
PSU 98's Avatar
I've been told one of the first symptoms of low trans fluid or need for maintenance is no OD gear. Knowing the code would be very helpful though.
Old Jan 26, 2009 | 08:26 AM
iosigma's Avatar
okay here is the code P0753B 1-2 Shift Solenoid Circuit...how do i repair that? Anyhelp greatkly appreciated
Old Jan 26, 2009 | 08:43 AM
LS1Tech Sponsor
That code is for shift solenoid electrical. The firstmove would be to change the 2-3 (B) solenoid
__________________
Call 888-744-6542
Old Jan 26, 2009 | 09:20 AM
You may want to do a quick visual of the external harness for any damage prior to removing the soleniod.
