How many different things does STR refer to?
Every converter company (actually designer) knows what Stall Torque Ratio (STR) is, and there is no other meaning for the abbreviation STR, in regards to torque converters.
FYI: If you measure the torque at the flexplate (say 300 lb/ft) and compare it to the trans input shaft measured torque at the true stall (say 600 lb/ft), that would be an STR of 2.0. Now you can only measure true stall by holding the input shaft RPM at zero rpms and going trying to go as many RPMs on the converter as possible. Although that rpm is heavily dependant on the output of the engine (measured flexplate torque), the higher at the flexplate/ engine output the higher the reading/stall will be. I used to test several converter combinations with B&M's converter dyno and I was able to fully understand the effects of different Impellers, Stators, Turbines, etc ... on the rated stall and STR of a converter. This is one reason why Vigilantes are believed to be under rated, they rate them at a different torque level then most. Typically converter makers will test converters at 300-400 lb/ft of torque, which is similar to the method GM used to test them at (not sure if they still do it this way).
As for Yank and the 1.6 STR, it was found on their now-out-of-production SY3500. They probably have not updated that tech page in a while. The lower the STR the looser it will feel, yet be more efficient up top. The higher the STR, the harder the hit on inital launch and tighter it will feel, yet be less efficient up top. This is because the multiplication is greater at low RPMs with a higher STR, which results in more (available) torque at the wheels, yet peaks and tappers off sooner.
From what I gather, PI actually has the equipment to check the STR of any converter, and this is how they select their parts.
But there are a handful of companies that use whats worked in the past, for example a customer wants x.xx str with x,xxx stall speed. Certain companies look it up in a book and just select the parts, verify fin angle, assemble the converter and ship it out.
Would you say this is close to an accurate statement?
I've seen a local shop do it. A Master Book, fin angle tool, and the parts.
Now that I own a C5 with over 900 rwhp, I would love to get a converter with a low STR so I can launch the car without destroying my output shafts or diff on the starting line.
I like hearing discussions from people with real experience through actual usage vs. theory. Theroy is good for the initial builds along with engineering, but nothing beats trial and error.
If no one replies to my question here I'm taking my money and using it somewhere else.
Does anyone think it's weird that certain companies jump all over guys that have no clue?
They post up a transmission problem that sounds like their trans is shot, and EVERY site sponsor replies.
I'm not experimenting with multiple $800 converters, sorry.
I believe in 2009 there should be a company out there that can get it right the first time.
I'm thinking of upgrading to a PT4000 with a 2.1str. It will still hit hard down low (it doesn't have as high of a str, but the higher stall should make it still hit about the same as a SS3600) and it will be better from a roll (more efficient up top). It will feel looser around town though being a low str.
Greg
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Greg
As a side note I have a a SS3600 with the 2.5 STR and it will barely move at all if I am at idle with the car in drive. If the road I am on is uphill at all or not smooth the car will not creep forward on its own, I would consider this considerably "loose" compared to the stock 1.89 STR.
And I started a thread here asking the converter builders to basically prove they have a converter dyno. I got this idea after googling and finding something on PBA's site written by PI about STR, how other companies test for it, and to outright ask to see their converter dyno so when you see they don't have one you know they're not building converters properly.
I've come to the conclusion that STR is pure BS. Same with converter dynos.
Unless you're building converters just to run on a converter dyno.
For us, the consumer anyway.
I think the answer is real world experience builds a converter, not a converter dyno.
I still don't know why only one converter builder replied to that post.
I think because he's the only one that has the confidence that he can build me a converter that will perform the way I want it to.
I've read so much about converters I've come to the conclusion that a good builder will get you what you want.
I sent a PM to the guy that replied. The conversation we had was short and to the point. Like one guy(me) knows what he wants and has specs, the other guy knows exactly what to do to build a converter to get me there. Simple. I can't wait til next Monday.
As far as the STR being BS, it basically is the ratio of how much torque is multiplied within the converter. There are differences in how people describe it yes but overall its the same thing. If you want a converter thats going to hit hard down low but not be as efficient up top then go with something 2.5 or higher and if you want something thats easier on the tires but more efficient on the top end then go with something lower than 2.5. From what I have read about it thats really all there is too it. I am still pretty sure a 2.5 STR converter is going to be looser feeling than the 2.0 converter on the street though.
Fyi thanks for asking 9000th this is the **** this site is here for
Correct me if this is wrong but my understanding is you can't directly compare STR from one converter manufacturer to the next because there is different combinations in building a converter that will give you similiar characteristics.
