Mustang guys I need your help (small leak)
Old 01-30-2009, 04:08 PM
5301113's Avatar
Unhappy Mustang guys I need your help (small leak)
Hey guy we have a 04 mustang GT and there is a small leak coming from a bolt or (plug) before the drive shaft . The bolt is on the driver side of the trans. Can I remove the bolt without lossing all the fluid so i replace the bolt or put some kind of sealer?
Old 01-30-2009, 04:10 PM
LS1Tech Sponsor
performabuilt's Avatar
If the bolt or plug is on the case you will loose very very little fluid there
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-30-2009, 04:25 PM
5301113's Avatar
Ok the thing is the car keeps droping a drop every day it a small leak but annoying as hell. I will post a pic of the bolt or plug later. Thanx
Old 02-17-2009, 06:29 PM
5301113's Avatar
Heres the pic, I think the fluid leaks from this plug with the red line. Can i replace it and will i lose alot of fluid?
Attached Thumbnails Mustang guys I need your help (small leak)-gt-transmission-drip.jpg
Old 02-17-2009, 08:03 PM
Marc 85Z28's Avatar
Removing that plug will not result in any loss of fluid. It's simply a plug for a hole that is no longer used. The o-ring on the other side of that plug will need to be replaced. It is causing the leak.
Old 02-17-2009, 08:57 PM
LS1Tech Sponsor
Yes thats where the speedo drive went on some cars, You could actually just take it off clean good and use silicone and put it back its not a presure area, Just a cover.
__________________
Call 888-744-6542
Old 03-10-2009, 07:51 AM
5301113's Avatar
I took y"all advise and it worked no more leak. THANKS
