Stall suggestions/ideas needed....
Old Feb 7, 2009 | 06:44 PM
Huggerorange73's Avatar
Default Stall suggestions/ideas needed....
Hey guys,
Need your opinions on the best stall for what I'm going to be using the car for.
It's a 99 Z28, mods as follows :
Lid, ported throttle body, LS6 intake, Hooker long tubes, ORY, Magnaflow cat back.
I have no plans on going any farther, with the exception of a stall...Even though it's got a 2:73 gear in it, I'd rather just leave well enough alone with the 10 bolt.
Car will see 99% street duty on street tires.
Thanks for the input!
Old Feb 7, 2009 | 06:48 PM
jetlag's Avatar
Yank SS3600.
Old Feb 7, 2009 | 06:51 PM
jsteele90's Avatar
dont buy anything under a 3600 in my opinion. i have a vig3600 which is a pretty loose verter. lots of people say the vigs are underrated and compare it more too a 4000 stall. i love it.
Old Feb 7, 2009 | 07:25 PM
performabuilt's Avatar
LS1Tech Sponsor
I would have to say around 3000 since you have 2.73 gears and plan to keep them . With a 4000 stall you would be doing near 70 in first gear at rated stall lol
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 7, 2009 | 07:32 PM
01z's Avatar
01z
what would you suggest w/ say a 410??? i ask because i will probably be doing a gear swap as my next mod. 273 are lame. good for highway if u dd i suppose
Old Feb 7, 2009 | 07:54 PM
LS1Tech Sponsor
With 4.10 3500 up its a different world with those gears
__________________
Call 888-744-6542
Old Feb 7, 2009 | 09:04 PM
Elliott's94Z's Avatar
I have always said the same (3000) if you plan on staying w/ the 2.73's...others disagree and say the SS3600.
Old Feb 7, 2009 | 11:52 PM
cals400ex's Avatar
if you plan on running street tires i don't think i would even get a stall. from what i have seen stalls do not help on street tires, even with better shift extensions. many disagree so it will probably depend on your combo but i have a feeling i would look elsewhere.
Old Feb 7, 2009 | 11:58 PM
crmartin99's Avatar
Get with Circle D and order they're street series. Mine drives like stock and stalls to around 3100. Very affordable too.
Can't wait to see how it does at the track!
