How long does it take you car to shift after command point ?
Old Oct 11, 2003 | 09:04 PM
Roger White's Avatar
Default How long does it take you car to shift after command point ?
After the install of my new PT4000 in my car it now takes 350-400rpm's to shift. Example Shift point 6600- and tags rev limiter at 7000 then shifts. Lower to 6500 and all is fine. I guess I need to atap my runs to see actual shift rpm.
Is this normal ? Does most of your cars do this?
Its costing me ET... Rev limiter
Thanks
Old Oct 12, 2003 | 03:55 PM
jimmyblue's Avatar
Moderator
Default Re: How long does it take you car to shift after command point ?
It's not the rev limiter that's the problem,
it's the grandma shift control programming.
Cutting down the shift adaptation time like
with Predator or other tuning will make a big
difference.
Old Oct 12, 2003 | 05:37 PM
I guess I should have said I have Edit and have done some major changes in shift areas.
I think I will try the OD vs. D thing. I searched and that seems like it may be what’s happening to me.
Old Oct 12, 2003 | 08:24 PM
The Guy in MY 99TA's Avatar
my car = no shift lag........ thanks to flp.... I usually manually shift mine since it doesn't shift high enough.... and I lost my HPPIII(or I beleive someone snagged it from my car at the track.... but too bad for them b/c my car is tuned!)
Josh S.
Old Oct 13, 2003 | 07:14 PM
Ragtop 99's Avatar
The slip from a high stall can confuse the computer.
2 solutions are to 1) adjust the shift point as you have done; or 2) adjust the shift delay table.
