Silverado Trans to Z28
Old Feb 16, 2009 | 03:58 PM
ZACHBROOKS95115's Avatar
Default Silverado Trans to Z28
Ok, so the car i am getting has a bad 60E (Reason i am getting such a deal on it) And i have a brand new 60E out of a Silverado. Will the truck trans work in the car? And it is a 2WD trans, not 4. I have heard that the bellhousings are different but it will still work. Can anyone clarify this??
Old Feb 16, 2009 | 04:05 PM
5.3LJimmy's Avatar
If the the silverado in question is the 96 model, then more than the bellhousing is different. The input shaft is a different diameter, the torque converter is made for this input shaft and has a different bolt circle, and the shift shaft is longer. This trans can be made to work in the car, but it will take a bit of modifying.
Old Feb 16, 2009 | 04:09 PM
Hmmm so would it be worth modifying? This is just a temporary trans until i get all the parts and money for a manual swap.
