Cracked flexplate :(
Old Feb 19, 2009 | 09:13 AM
streetassasin's Avatar
Default Cracked flexplate :(
I got a call this morning from the trans shop that is installing my trans and stall saying my flexplate is cracked. I was planning on taking it to the track this weekend but am not going to be able to, I'm waiting for them to call back then will probably have to overnight a TCI, its an extra $250 that I didnt want to spend
Old Feb 19, 2009 | 09:34 AM
cookba's Avatar
what kind did you have that cracked? TCI? i saw that speed inc makes one, im in the market for one but i definitely dont ever want one to crack on me.
Old Feb 19, 2009 | 09:36 AM
no a stock 01 with over 127k miles, Im going to probably order the tci
EDIT: Just saw the speed inc one and am about to give them a call
Old Feb 19, 2009 | 09:38 AM
cookba's Avatar
let me know what you find out, i wonder what the differances are? quality as well?
Old Feb 19, 2009 | 09:52 AM
From speedinc's site:
TCI
TCI SFI LS1 Flexplate
Race safely with TCI's newest addition to our extensive flexplate line. The TCI 399753 flexplate fits 1998 and newer F-bodies with LS1 engine as well as ’99 and newer GM trucks with 4.8L, 5.3L and 6.0L LS based engines.
SFI 29.1 approved Lightweight design for quick engine response Made in the USA from plasma-cut, Blanchard-ground, billet steel plate
Includes mounting hardware
Dual bolt patterns, stock LS1 and small GM bolt pattern
itemno description price buy
TCI399753 TCI Automotive SFI Approved LS1 Flexplate $204.99
Speed Inc
Speed Inc SFI Flexplate
Fits all LS-Based Auto Transmission Equipped F-bodies, GTO, and Trucks. Affordable upgrade, which is SFI 29.1 Approved. Features dual converter mounting holes for 4L60, 4L80, TH350 and TH400 Transmissions. Zinc coated for corrosion resistance.
CATFP346 LS1/LS2 F-body/GTO, Truck SFI Approved Flexplate $119.99 buy
I figure the speed inc will be plenty strong for my combo, heads/cam n2o 346" so I already ordered it and had them overnight it, Ill post pics when I get it
Old Feb 19, 2009 | 10:28 AM
CarsandWomen's Avatar
im sorry to hear that man but from what i can tell it happens regularly. seems the 98 and 99s have a heavyer but stronger stock flexplate than the 00 through 02. not a bad upgrade though if you think about the damage they can do when they come apart.
Old Feb 19, 2009 | 11:47 AM
omcar's Avatar
Mine cracked as well...Went with a TCI (sfi).
Old Feb 19, 2009 | 02:40 PM
JohnFrazee02SS's Avatar
I had that happen to me too and got the TCI flexplate. Its worth it.
Old Feb 20, 2009 | 09:52 PM
098z28's Avatar
my stock 02 one cracked too with less than 70k i bought the one from speed inc its made by cat and its sfi 29.1, its really a nice peice and the starter ring is alot thicker then the stocker which is where mine cracked in several spots
Old Feb 20, 2009 | 09:53 PM
098z28's Avatar
if i had the cash i would have went with the TCI tho...
