Scared to go from Yank SS to the PT
its to bad he red lighted on our 1 run & he got me by a long car length,it would of been an awesome race other wise,i know he just hit the 10s for the first time that night & i ran a 11.08 @ 121 with a 1.48 60' full weight.
i have the FLT lvl4 & pt4000 in a heads & cam car & make 407 rwhp & chris1313 makes 422 rwhp cam only car.
i would say chris1313 is running right where he should be at 10.8x with 422rwhp & lightened up, whats astounding to me is that his car makes 422 rwhp CAM ONLY!!!!!!!!!!
they are obviously doing something right...........................
i mph at 122 while he was at 121...so i am making 10rwhp more...so add 1 tenth on my ET...i am at 10.91 at 121 now...he is 11.08 at 121...
now it is apples to apples...or as close as we can get...
you can go the other way too my (10.82 at 122mph) to his added 10rwhp to a 10.98 at 122mph...
Sorry HEYMOEJ didnt mean to use u as the guinea...although u did bring up my red light
that reminds me if you think my 422 is good check out demonicbird's dyno pulls i think he pulled 456 through an m6
So now if you apply that to my car and heymoej you get the results I posted…I would be in this case the car that would need to add 100 lbs because my mph is 1 higher…so by adding 100lbs my time would slow down to about 10.91 at 121mph…with that being done both cars are making the same power to weight ratio…he is overcoming his added weight with heads…this is why it was a good example to use to compare the two converters cause both cars are close in mph…so if both converters were equal we would run the same ET…obviously track conditions come into play too…
Also FYI my 60ft would be around a 1.40-1.41 with an added 100lbs…
And full weight for me is around 3600lbs so add 300lbs and I would be at around 11.11 at 119mph…FULL WEIGHT…but this doesn’t compare the two cars apples to apples because heymoej would have a better power to weight ratio, easily seen by the difference in mph from 119 to his 121…
How would he have better power to weight ratio if you were both 3600lbs and he dynos 15rwhp less than you. See how stupid that sounds. He just has a more efficient converter. That allows more power to be put to the ground during a pass.
Not to mention that he may or may not have a ram air kit and still I bet you would say that yours is better (unless he has one of yours). Which would skew the results even more in your favor.
And I love how you live by the rule that 100 = .1 = 1 MPH. It's a good rule of thumb but it's not an exact science. Hell, you could put that weight back in your car and it still may be faster.
Get my point?
Racing in a class makes all the more reason to have the most efficient best working parts on your car. Sometimes it might be a hard choice between leaving the line harder or pulling harder on the other end.
Of course you could just get a SS4000 and have the best of both worlds, right?
I wonder why they even make the PT series if the SS performs better in every aspect and is cheaper? Last edited by StealthFormula; Feb 24, 2009 at 12:55 PM.
I wonder why they even make the PT series if the SS performs better in every aspect and is cheaper?I can dyno at one place and make 422rwhp or another shop and only make 380rwhp, also maybe his converter was not locked and mine was…how can you base anything off of dyno numbers…your whole reasoning by the dyno numbers is flawed…when it should be based off of mph…
My experience that my SS converter is a beast off the line and still makes good mph on the top end…what would you expect to gain mph wise from a 230/230 cam and 85mm lid/maf setup over an aftermarket lid and descreened stock maf…
I gained 7mph (I have trapped 123 in -900 ft DA) apples to apples…
I said I had to add weight to make the cars the same power to weight ratio, and used the example of class racing to why I added the weight…to make the cars even, mph wise…
Maybe my car is slipping really bad on the top end and my SS is eating up a bunch of hp, but how much more do you think I have left in my setup…so if I get a PT I will mph in the 124-125 range…so my gain from SI to CAM ONLY is ~80-90rwhp with a 230/230 cam and 85mm lid/maf…It’s not like my car was on a bad tune SI…
Bottom line- We each have our own opinions I was stating mine with what I have experienced…
, you would be changing the efficiency of the converter. I gained 3mph from the stocker to the PT4000, you think my unlocked dyno number would be 30rwhp more than what it was? It's not about peak hp. It's about the average of how much you are putting down for every inch of the track. Yank seems to think that the PT is more efficient and has bigger shift extensions than the SS.Your experience must even exceed that of the people who make the converters and claim the PT to be the better NA converter.
