rebuild or new ?
Old Feb 20, 2009 | 01:19 PM
Black_Jack's Avatar
Exclamation rebuild or new ?
i have a auto 2000 t/a i blew trans in it pretty bad, every one ive talked to thinks that my front pump went out, but im not a trany expert so idk.
it blew alot of trany fluid (nerley all of it) out the brether on the top of the tranny and the car would die if i let the rpms drop down to far, then i herd loud clanking from the tranny 3 times then the whole car shut off, it also broke the starter.
there not much done to the car just tranny cooler, o2 sims, gutted catts, ported t/b, slp lid, and msd wires and the free mods, 3'' cat back magnaflow
well i just got it out of the car and i know some one that says he worked for gm for 13 years and he could rebuild it for 100 buck plus parts and i found a full rebuild kit from advances for bout 150 bucks so any advice would be great thanks, and will i need a new converter or can the one i got be fixed ?
also i dont got much money right now, and i plan to do a m6 swap eventually i just need the car 2 run for right now
Old Feb 20, 2009 | 03:30 PM
7998's Avatar
If your on a tight budget, and need your car running, and trust your friend rebuilding it then $250 ain't bad. If you really think he can fix it, Is he gonna check the hard parts out and everything else or just put a rebuild kit in it for you? You might want look at some used options as well.
Old Feb 20, 2009 | 04:46 PM
Dex's Avatar
Dex
Thats a good deal i would take him up on it. I know its gonna be more than $250 im sure it wiped out some hard parts which can get costly depending on what broke but its usally cheaper then a new trans. There actually really easy to rebuild they just require special tools thats what makes them a pain in the *** for the normal person.
Old Feb 20, 2009 | 07:04 PM
9000th01ss's Avatar
A pump breaking and a starter breaking at the same time is real odd.
I'd say you just broke the flexplate and it made the noise and took out the starter. But that doesn't explain the fluid coming out.
Might plan on adding a new flexplate to your budget.
Old Feb 24, 2009 | 03:25 AM
Black_Jack's Avatar
the whole's on the flex plate where the convert bolts up are a lil rounded out, maybe cause of the starter braking ? so u think i need a new converter ? or just freshend' up ?
Old Feb 24, 2009 | 07:56 PM
heymoej's Avatar
i would call FLT.........
Old Feb 25, 2009 | 09:50 AM
Black_Jack's Avatar
any other help ?
Old Feb 25, 2009 | 11:50 AM
9000th01ss's Avatar
Originally Posted by Black_Jack
any other help ?
Seriously, it's time to dust off the ole tool box and start working on the car. No amount of guessing on the internet is going to do you better.
Old Feb 28, 2009 | 12:47 PM
Black_Jack's Avatar
i've got the tranny out the car right now, i just need to know if it's worth rebuilding and if i need a new converter
Old Feb 28, 2009 | 03:50 PM
chevyz2801's Avatar
If you rebuild it i have a pro yank 3400 converter with under 6k on it for 700 plus shipping.
Old Feb 28, 2009 | 03:58 PM
9000th01ss's Avatar
I've got a Circle-D 3c for sale right now 26 days old and under 700 miles on it for $600 plus shipping.
Old Mar 2, 2009 | 06:24 PM
Black_Jack's Avatar
im just looking for stock parts. i plan on switching it out for a m6 later on i just need to get it driving for now
Old Mar 2, 2009 | 06:25 PM
Black_Jack's Avatar
so does any one have any helpfull suggestions ?
or a stock working 4l60e w/ converter for a good price
