Got the SS4000 Installed.
Old Mar 1, 2009 | 04:06 PM
jarednut4ever's Avatar
Default Got the SS4000 Installed.
Well the install was pretty easy. Replaced the flexplate with the hughes SFI. So far I love it drives real good not to loose. I still have the stock 3.23 rear. I only have 100 miles so I haven't got on it off the line, however I have got on it from a 50 roll and all I can say is damn, what a difference, I have a small vibration And the cause I believe is I installed polyurethane trans mount and torque arm bushings And they are really stiff. I checked the BMR loop for clearence probs but no rubbing anywhere. So It must be the mounts, and like I say very minimal vibration only under wot at 5500+ rpms. Our first test and tune is in two weeks so I will keep you guys posted with the results.
Old Mar 1, 2009 | 04:37 PM
Intercooler2's Avatar
Did you eliminate the codes? It bit me yesterday
Old Mar 1, 2009 | 05:00 PM
Which codes. I haven't changed the codes yet. So far no codes.
Old Mar 1, 2009 | 05:09 PM
Search for my post in here. Nobody told me either you have to eliminate them and some people don't get them. You may be lucky for a bit like me.
Old Mar 1, 2009 | 05:49 PM
Must be the p0751 and p0757, Also to change lock-up. I will go tune that tonite, thanks for the info.
Old Mar 1, 2009 | 07:45 PM
Got it all tuned. I got on it a little from a 10 roll, Its def got some *****. Spins the M/T's pretty good from a 10mph roll. I am likin it
Old Mar 1, 2009 | 07:54 PM
jetlag's Avatar
The Yank converter was one of my favorite mods, other than the nitrous.
Old Mar 1, 2009 | 08:14 PM
The shift extension is great stays at 5000+ the entire time. Actually feels a little faster in 3rd past 90 mph.
Old Mar 1, 2009 | 09:14 PM
Twotonefreak's Avatar
Good to see your liking it. I just put my ss4000 in a couple weeks ago. I love it!
Old Mar 1, 2009 | 09:59 PM
Rick2006's Avatar
I just got my ss3600 install yersterday also... Man what a difference!!! can't wait for the Chevy Show this weekend...
Old Mar 2, 2009 | 11:44 AM
JScamaro's Avatar
AS far as the vibration goes, I have read bad things about using the poly trans mount. A poly mount for the engine is ok though.
On my setup I have a poly motor mounts and stock rubber tranny mount and have no vibrations.
Old Mar 2, 2009 | 12:40 PM
chrs1313's Avatar
wait till you get on a preped track with that new stall...gonna put some daylight under those front tires...
Old Mar 2, 2009 | 03:29 PM
It is a small vibration so not to concerned. I wanted the stronger mount because of the stall. I am going to check the loop tonite and drive it some more.
Old Mar 2, 2009 | 08:14 PM
Well I changed out the poly mount tonite with another rubber one. No more vibration. Poly mounts really suck. Thanks for your help guys.
Old Mar 2, 2009 | 08:17 PM
TurboAv's Avatar
I thought my 4000 stall was badass. But it's like crack. I want more, lol. I'll probably jump it up to 4800 next.
Old Mar 3, 2009 | 12:09 AM
jetlag's Avatar
Ha, same with nitrous.
Old Mar 3, 2009 | 09:30 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Turboav let me know when you are ready.
Thanks,
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
