Shift Points?
Old Mar 2, 2009 | 08:02 PM
Tee1up's Avatar
Default Shift Points?
Where should the RPM shift points be set with and w/o
150 shot with built A4?
Old Mar 2, 2009 | 08:06 PM
performabuilt's Avatar
LS1Tech Sponsor
That varies alot from car to car and transmission to transmission, Converter size comes into play. Rear ratio, Power band and power of car. You might get a baseline from someone with similar mods and trans in there car but dialing it all in will be hands on.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 2, 2009 | 08:08 PM
Tee1up's Avatar
Thanks
Old Mar 2, 2009 | 08:51 PM
tording99Z28's Avatar
The points with the 150 shot are probably gonna have to be commanded a little earlier than with the NA setup. The nitrous will make the rpm's climb faster and there is always a little bit of a delay between the time the shift is commanded and the time it happens. Its just the nature of electronic transmissions.
Old Mar 3, 2009 | 02:41 AM
LS1Tech Sponsor
True and additionally its the nature of any hydraulic trans, Wether full manual or electronic it takes time to fill the hydraulic circuts
__________________
Call 888-744-6542
