Everyone with TCS 4200s, please come in
Old Oct 16, 2003 | 06:01 PM
quickWS6's Avatar
Default Everyone with TCS 4200s, please come in
What kind of shift extension does everyone get? I am only getting around 5000, I think it should be more. The converter was stalled for a stock internal car, and since I have added a 224 cam, so it should be stalling even more then before, which would raise the shift extension I would think. Thanks!
Old Oct 16, 2003 | 06:19 PM
Z-Rated's Avatar
Default Re: Everyone with TCS 4200s, please come in
you talk like 5000 is low, sounds good to me but what do I know?
Old Oct 16, 2003 | 06:30 PM
Mitch's Avatar
The shift extension of my TCS4200 is about 5700 RPM. My car is a C5 with H/C. Where are your cars shift points set at? If they are too low that could be part of the problem. My car shifts at 6500 RPM.
Heads and Cam, LS6 Intake, TPIS LT Headers, TCS4200, 3.73 gears, Comp push rods, Borla Exhaust,
Old Oct 16, 2003 | 06:58 PM
quickWS6's Avatar
My car shifts at 6500 also. 5000 is a good bit lower then what I was hoping. Some 3500 stalls get 4700-4800 on the shifts. I'm looking for 5500-5700. Thanks for your input Mitch. What is everyone else getting.
Old Oct 16, 2003 | 07:38 PM
Ragtop 99's Avatar
depending upon what style 4200 you had built, I would expect either 5000 - 5200 or 5500 - 5700. Different STR combinations will result in varying drivabilty and shift extension.
Old Oct 16, 2003 | 07:58 PM
Mitch's Avatar
Most of the other TCS4200 owners seem to be getting about the same shift extension I am getting. You are right about some of the 3500 stalls, I had an ST3500 that had a shift extension of about 4800-4900. I see that you are stock internally, perhaps Derek sent you a 4200 that was setup to work with a H/C cam motor, that might account for the low shift extensions. What shift extensions did Derek tell you to expect?
Old Oct 17, 2003 | 12:19 AM
quickWS6's Avatar
I ordered the stall and ran it for a while with stock internals. I ordered it from Mikey at Rapid. I specified for a 4200/2.7STR for a stock internal motor with best ET in mind. Oh well, as soon as I get the cash, it will be replaced by a new Yank anyway.
Old Oct 17, 2003 | 09:06 AM
CamaroCain's Avatar
5300-5400 on my bolt-on car
Old Oct 17, 2003 | 12:36 PM
2001-WS6's Avatar
You probably don't want to consider mine since it was clearly out of spec with stall around 5100-5200 but the shift extension was running about 5800-5900. Nothing quite as humorous as blowing through from 5900-6600 NA on converter that was supposed to hold up to a 200HP shot. :eek
Rick
