TH350 speedo problem
Old Mar 6, 2009 | 09:19 PM
cainsw's Avatar
Default TH350 speedo problem
I have a 99 M6 Z28 4.11's that I changed over to a th350 and I am having a problem with speedometer. I spliced into the front drivers wheel sensor and tied it in to the black trans speed sensor. Then I measured the tire (81 inches) and divided 3.14 to get the actual tire height of 25.79 and reflashed the pcm to 2.76 gear ratio. Now it is nowhere near what it should be. I put the gps in the car and at 40mph the speedo is showing about 18-20. What could I have done wrong? Could the wires be backwards or did I forget something?
Old Mar 6, 2009 | 09:24 PM
9000th01ss's Avatar
Do a rollout measurement on the tire. Thats the closest to factory tire size programming that you'll get.
What number are you using for pulse per revolution?
Old Mar 6, 2009 | 09:41 PM
cainsw's Avatar
In my HPtuners This is what I have
General VSS Pulses per:
Mile=86348
Rev-Trans=40.0000
Final Drive Ratio=2.76
Trans Revolutions/mile=2158.7108
Old Mar 6, 2009 | 09:42 PM
cainsw's Avatar
Roll out was 81 inches
Old Mar 6, 2009 | 10:17 PM
9000th01ss's Avatar
That sure is a tall front tire. You using the front vss's or ???
Old Mar 6, 2009 | 10:31 PM
cainsw's Avatar
It's only a 26 inch tire.
I'm using the front driver side wheel sensor. Did I not measure it right? I read that you need to measure around the tire, I did that and came up with 6ft 9inches=81inches then divided by 3.14 and that gave me 25.79 inches for tire height
Old Mar 6, 2009 | 10:39 PM
9000th01ss's Avatar
FYI rollout measurement is not wrapping a tape measure around it.
Whats the sidewall say the size is? Example 215/60/15
Old Mar 6, 2009 | 10:41 PM
cainsw's Avatar
26x7.5x15lt Mickey Thompson skinny
Old Mar 6, 2009 | 10:50 PM
cainsw's Avatar
That was just something I read
Old Mar 6, 2009 | 11:52 PM
cainsw's Avatar
Anybody got any ideas?
Old Mar 9, 2009 | 09:10 AM
pddye's Avatar
This is what I have in mine. I've got metric radials on the front but I think they are 26" tires. Works well for me and it might only be off by 1 mph at 70.
Mile - 40688
Rev Trans - 40.0
Final drive ratio - 1.17
Trans revolution per mile - 755.0976
Old Mar 9, 2009 | 09:12 AM
pddye's Avatar
There is a writeup on how to measure your tire to figure out your correct ratio but i'm to lazy. This will get you in the ballpark tho. I had to do some adjusting on mine to get it a little closer to my tires.
Old Mar 9, 2009 | 09:25 AM
cainsw's Avatar
I figured out what the problem was. I forgot my operating system was updated to an 02 and that was an auto setup. So I had to enter the auto gear ratio and all is well. Thanks for the help
