Where did you put your tranny temp sensor?
Old Mar 15, 2009 | 03:45 PM
witry's Avatar
Default Where did you put your tranny temp sensor?
i have a B&M pan the 3 qt extra one and i put mine in the bottom portion almost by where the pickup hole is in the filter and when its cold here in FL 40 50's o harly see the temp move from 100 degrees but today it was 85 here and sat in traffic and it got to 155ish so am i picking up the right temp or is my sensor in the wrong spot and also the sensor is on the back side on the pan not side
Old Mar 15, 2009 | 03:53 PM
1BAD_LS1's Avatar
Restricted User
Mine is in the side of the tranny and I am around 150ish on the highway and 180-200 messing around town in 60 degree weather.... I have a tranny cooler also...
Yours are low compared to mine.... think i might need ANOTHER tranny cooler or something...... What is the normal operating temp of a 4l60E?
Now im worried....lol
Old Mar 15, 2009 | 04:08 PM
witry's Avatar
well my tranny cooler is the biggest B&M out there the 29,000 one with the radiator bypassed and fans on all the time well almost all the time
Old Mar 15, 2009 | 04:09 PM
witry's Avatar
if you have yours on the side they say you will see average 15-20 degress higher temp the actual temp in the pan so they say
Old Mar 15, 2009 | 04:54 PM
FLT's Avatar
FLT
The reading in the pan is the most accurate place to read temps. I think you have it in the right place! Vince
Old Mar 15, 2009 | 05:04 PM
witry's Avatar
even tho the temp reading verys so much? like when it was in the 30 and 40's here i never seen it move from 100 dgress the gauge reads 100-250 but its 85 now and it reads 155 thats ok then? if so then thanks for the info
Old Mar 15, 2009 | 05:10 PM
FLT's Avatar
FLT
I think you are ok!
Old Mar 15, 2009 | 05:32 PM
performabuilt's Avatar
LS1Tech Sponsor
I would agree with Vince also the temp range your seeing is well within normal range and sounds like your guage is reading right for your enviroment.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 15, 2009 | 05:39 PM
Randy WS6's Avatar
Mines in the side of the pan.
Old Mar 15, 2009 | 08:29 PM
GMRL's Avatar
On the feed line to the cooler.
Old Mar 15, 2009 | 09:56 PM
witry's Avatar
thanks FLT and Performabuilt you guys are awesome thanks for the info and reassurance now i wont look at the gauge every 2 seconds
Old Jul 22, 2009 | 11:48 AM
Big_Bird_WS6's Avatar
^^^ wouldnt this be the best? or work really really good. so i dont ahve to drop the pan.
Old Jul 26, 2009 | 04:57 PM
HitmanLS1's Avatar
Does the temp sensor come with the tranny gauge
Old Jul 28, 2009 | 03:30 PM
Gatsby's Avatar
Most do, autometers all come with it. You'll just need to by a length of 18ga wire to run from the sensor to the gauge. Very easy install.
