didnt seat my converter all the way and messed up my pump
yea i got it all bolted up first. then i turned the engine over and noticed it took a LOT of effort. i assumed it was because hadn't been run in a while and was all nasty. but that was not the case, obviously. i didnt think to check the converter, because i didnt think it had been tilted forward. then i rememberd that it did once and was like DOH!!!
LS1Tech Sponsor
This unfortunatley is the single most comon mistake. Even when the car is never started it can damage the pump and failure happen either imediatley on start up or shortly there after.
Its very possible the converter hub could be damaged and should be checked very carefully.
Sorry for your missfortune.
__________________
I skipped the obvious, first make sure the converter is in the trans all the way before you even aim them at each other. There is no three click bullshit. I don't even know anymore, you can just tell when it's in all the way.
https://ls1tech.com/forums/automatic...allations.html
