Effin trans! Again!
Old Apr 18, 2009 | 08:01 AM
  #101
2002CAMAROSSLS1T56's Avatar
Originally Posted by 9987ta
Insane crap about the lifters? I guess you never had a engine stick all the valves open because the lifters pumped up and won't relieve.
Thats not the insane part, the insane part is that it was the trans, maybe the cats, maybe the brakes dragging, maybe this, maybe that. Then the lifter scenario pops up. Very inconsistant with the other 'maybes'
If you want to get to the root of the problem on your own, get a vacuum gauge, you know the good old fashioned way connect it, make the problem happen look at the gauge. theres the answer to your lifters (or not) right there. What happens when lifters stick--the gauge goes screwy. Same results if the cats were clogged.
Personally I'd run it with a fuel pressure gauge on it and look at that when the problem is going on--at a different time than doing a vacuum test.
Going by your descriptions now I'd say check the map sensor--it's in the back of the engine and could be damaged since the engine needs to lean back so far when the trans comes out.
Also look at the wiring back there, I was bolting up a trans once and found the wires between the engine and trans about to get pinched, thats why I look.
Take the cats off and inspect them.
Make sure the check engine light actually works.
Take the trans out and try to ID the converter. What are the odds the car had a mild converter in it and it got swapped with the trans work? Still it could have a truck application, low stall converter in it now, somehow.
I'd pull the tune out of the computer and verify it was stock.
Just for the hell of it I'd put a pressure gauge on the trans.
I'd check the MAF for something stuck in the screen.
Since it seems to be beyond an obvious problem I'd test some not so obvious stuff.
And again personally I have hp tuners so I'd run with that connected
Old Apr 18, 2009 | 08:25 AM
  #102
mikey's Avatar
LS1TECH Sponsor
I just diagnosed the car. He's not crazy. It is knocking something aweful. Looks like a fuel pump issue. The PCM is switching over to the low octane table which is causing his loss of power.
Old Apr 18, 2009 | 09:15 AM
  #103
But he said the fuel pressure was checked several times and wouldn't take any advice to futher diagnose it because it 'was not the problem'.
Old Apr 18, 2009 | 10:37 AM
  #104
mikey's Avatar
LS1TECH Sponsor
Ultimately engine detonation is the problem. Whether it is a fuel pressure issue, blocked filter, blocked cats stilll remains to be diagnosed. I did not have time for that today. I suspect a fuel system issue but it may lead to something entirely different once I get into it.
Old Apr 18, 2009 | 01:24 PM
  #105
Thats good, I know nothing of your business but it looks like his car is in good hands.
And needless to say, he really needs it.
Old Apr 18, 2009 | 03:33 PM
  #106
9987ta's Avatar
Thank You Rapid Motor Sports I know what is going on now! Unfortunately on the way home the pump started screaming and the car barely would move. I'm going to have the fuel filter changed again and hope it runs. I tried turning the key on and the pump just whines.
I called the shop that changed the filter last week and he told me the filter he removed was COMPLETELY BLOCKED.He could NOT blow ANY air through it. He also mentioned what ever it is is so fine you can barely see it. I hope it doesn't block the screens in the injectors yet!
Again Thank you Rapid for finding an answer in a few mins that TWO GM dealers couldn't find in 4 hrs!
Old Apr 18, 2009 | 03:34 PM
  #107
9987ta's Avatar
Don't be smart azz! next time it will be your turn and i'll beat up on you buddy boy!
Old Apr 18, 2009 | 04:13 PM
  #108
I told you to check the fuel pressure a long time ago, you said it was good. I recently said to check it while driving or until the problem shows up.
You need to learn to take advice. You never planned to fix it yourself, this thread was a huge waste of time. You just needed to find the right shop, theres no way this thread helped you do that, this was just an outlet for your frustration and nothing more.
Old Apr 18, 2009 | 04:15 PM
  #109
Old Apr 18, 2009 | 04:39 PM
  #110
9987ta's Avatar
I'm telling you the fuel pressure was 61 when we checked it...now there is nothing. Sorry my fuel pump isn't on your schedulemaybe next time you can ask at the appropriate moment in time and you will receive a lollipop
Old Apr 18, 2009 | 05:36 PM
  #111
9987ta's Avatar
When its your thread you can post as you please...i'll do the same...so take a big can of SHUT UP and start gulping!
Old Apr 18, 2009 | 07:19 PM
  #112
9987ta's Avatar
I gotta add this to this thread...
BOTH GM DEALERS CLAIMED
NOTHING WRONG WITH THE CAR
ALL DATA GOOD
I guess you can take any GM dealers service advice and toss it in the dumper!
Can you imagine how many cars are out there with major trouble that don't get fixed till they stop!
Old Apr 18, 2009 | 07:54 PM
  #113
wtf happened?
Old Apr 18, 2009 | 09:35 PM
  #114
9987ta's Avatar
Igit!
Old Apr 18, 2009 | 09:37 PM
  #115
9987ta's Avatar
Mike at Rapid is a class act, he looked at and found the cause quickly. Didn't charge me anything to look at it.
THANK YOU
Old Apr 18, 2009 | 10:02 PM
  #116
THANK YOU
Try to not drive him insane ok.
I can't wait til part IV what shop 10 screwed up, and the noise I hear now between 10.3 mph and 10.4 mph when it's 84.35 degrees F outside.
So whens the next update? I know Sunday he'll be off, but if you have a dream about the car should I tune in tomorrow?
Old Apr 19, 2009 | 03:15 PM
  #117
9987ta's Avatar
Car isn't drivable anymore........guess i'll have to tow it down there. has fuel pressure but will barely run.
Old Apr 19, 2009 | 03:33 PM
  #118
9987ta's Avatar
Hey stop with your Bs NOW! I heard enough already. I need mikes not you trying to rev him up! So stop yer crap!
Old Apr 19, 2009 | 05:31 PM
  #119
It's the crank position sensor. During the first trans removal the mechanic damaged it or the wires while taking the starter out to get to the torque converter bolts.
Old Apr 21, 2009 | 08:27 PM
  #120
9987ta's Avatar
Well the trans is cooked again....Mike you heard it makng noise now its vibrating the entire car. I guess GM can't do anything right anymore. Disgusting!
