Problem, Please Help! With A4!!!!!
Old Oct 24, 2003 | 11:39 PM
beardWS6's Avatar
Question Problem, Please Help! With A4!!!!!
I`ve had the tranny rebuilt by Century in Houston. What my problem is every once in awhile my overdrive seems to slip really bad. When I down shift to drive its okay. Now when I turn the car off and restart it fixes the problem, and works in overdrive. It flips a code and I had MTI look at it. Seems the valve sticks open in overdrive. I have had it replaced once after the rebuild. This has happen to me 4-5 times again. The service light clears most the time on it`s own. This last time it stayed. Is there anyway I can clear it and what do you guys think? Tranny shifts good and hard all the time, just every now and then this happens!
Old Oct 25, 2003 | 02:00 AM
Pete2k_Z28's Avatar
It's possible they over torqued the valve body. What is the code?
Old Oct 25, 2003 | 06:50 AM
blaSSt's Avatar
Have you talked to Mike at Century? Is it past the warranty period? I've always found him to be very helpful.
Old Oct 25, 2003 | 02:49 PM
TA2SLOW346's Avatar
Sounds like your converter isnt staying locked in OD. And once you shut it off and restart it, its fine for awhile.
