10 second capable - highway friendly, not M6...
Old Apr 14, 2009 | 10:50 AM
INSSANE's Avatar
Default 10 second capable - highway friendly, not M6...
Any suggestions?
I was looking into a TH400, but from what I understand, only having the three gears makes the car very highway unfriendly (obviously).
What are some highway friendly options for a tranny in a 10 second ride?
Old Apr 14, 2009 | 11:21 AM
performabuilt's Avatar
LS1Tech Sponsor
All the sponsors here including us have cars running the 4l60e in the 10s and The 4l80e is definatley a good choice also.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 14, 2009 | 12:58 PM
slow67's Avatar
Gingervitis Addict
I have a 4L80......
Old Apr 14, 2009 | 01:35 PM
heymoej's Avatar
Originally Posted by INSSANE
Any suggestions?
check with vince & chuck @ FLT ............
they make a stout 4l60e,you will be glad you did............
good luck!
Old Apr 14, 2009 | 02:20 PM
01ssreda4's Avatar
i agree......
Old Apr 14, 2009 | 11:34 PM
dnkynrbk's Avatar
check with Frank ran over a 100 low 10sec passes in my car for over 2 1/2 years and the tranny is still going. LV2 Performabuilt. was a daily driver and went on 4 hour roads trips car ran very good in OD. I luv the passing power too. Now I have a new set.
Im now running there t400 tranny for a 10.5 drag class.
Old Apr 15, 2009 | 06:53 AM
forcd ind's Avatar
part of the biggest problem is the converter stall-tighter for the street, not as good for the track
i use a 4l80e, runs 10's and runs 65 mph at 2k, converter locked-best of both worlds
by having a lockup converter, takes the high stall out of the picture on the highway
Old Apr 15, 2009 | 10:55 PM
dpw41285's Avatar
Default rpm level vi
this is what i was using when i planned on putting her in the tens all 4l65 internals and a t brake with overdrive. the rate it to 1000hp, yeah the stall is loose for the street but at75mph its locked up. i took it on 3hr dr no overheating or anything. btw its for sale https://ls1tech.com/forums/lsx-parts...built-rpm.html
Old Apr 15, 2009 | 10:58 PM
dpw41285's Avatar
wow that looks bad sorry i was typing on the i pod touch
