Input Drum Stuck
Old Jun 12, 2009 | 04:06 AM
TKhawk01's Avatar
Default Input Drum Stuck
I'm rebuilding my second 4L60E and having trouble getting the input drum out. We've got the low reverse drum off of it and yanked and yanked on the input shaft but it won't come out, I don't remember it being near this tight on the last one. Any suggestions, thanks.
Terrence
Old Jun 13, 2009 | 09:14 PM
TKhawk01's Avatar
Any ideas, It's supposed to be a performabuilt level 2 that had third and forth gear slippage. The valve body and everything else that has come off looks good so far.
Old Jun 14, 2009 | 10:16 AM
darkhorsebob's Avatar
Sounds like the 3-4 clutches are burned so badly they won't disengage from the front ring gear. I've used a large pair of vise grips with a nut welded on the end, so I can use a large slide hammer to ****** the drum out. Some can be extremely difficult to remove depending how badly the clutches are warped.
Old Jun 14, 2009 | 11:16 AM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like the 3-4 clutch is wielded or seized to the front planet. try carefully so you don't break the case dropping the unit evenly on the bell sometimes works to get them loose.
When you have a chance PM me the number stamped at rear of case if you don't mind.
Thanks
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 14, 2009 | 01:10 PM
TKhawk01's Avatar
Ok, thanks, I'll give that a try. I'll send you that number when I get down to the shop.
Old Jun 17, 2009 | 02:53 PM
TKhawk01's Avatar
Thanks dropping it on the case worked great. There is definitely heat discoloring on the 3-4 cluch snap ring. And the teflon seal closest to the input drum on the input shaft is messed up. I'll get pics up later.
Old Jun 17, 2009 | 11:55 PM
TKhawk01's Avatar
Seams its not a performabuilt trans. Thanks for everyones help.
Old Jun 18, 2009 | 01:36 AM
LS1Tech Sponsor
I was wondering when the numbers did not match and I did not have a failure report . Good luck with it anyway and if you need anything just holler
__________________
Call 888-744-6542
Old Feb 2, 2022 | 02:10 PM
Thomasbb22's Avatar
Default My forward drum is stuck onto the planet won’t come off
Originally Posted by performabuilt
Sounds like the 3-4 clutch is weilded or seized to the front planet. try carefully so you dont break the case dropping the unit evenly on the bell sometimes works to get them loose.
When you have as chance PM me the number stamped at rear of case if you dont mind.
Thanks
my forward drum is stuck onto the front planet will not come off have wiggled it till I can’t no more any advice on how to get this off could the piston be stuck? Causing it not to disengage from the planet
Old Feb 2, 2022 | 04:40 PM
LS1Tech Sponsor
Be careful to drop even but sometimes dropping trans down on bell evenly will dislodge the drum . Some risk of damaging bell is there that is why i say evenly drop short distance , Watch your feet. The 3-4 clutch is probably seized to reaction or front planet has exploded.
__________________
Call 888-744-6542
Old Nov 1, 2022 | 06:51 PM
ANADALES's Avatar
Terrence
did you solved? I have the same issue, the input drum is stuck
Old Nov 1, 2022 | 10:24 PM
bbond105's Avatar
Have you tried dropping the trans evenly on the bell housing? Try to keep the bell housing square with the floor so not to break the case
