transgo S/K question about changing washers
Old Nov 11, 2003 | 08:58 AM
1/4master's Avatar
Default transgo S/K question about changing washers
can anybody that has installed their own (i had mine done), tell me how to add or remove washers to adjust shift firmness?
TIA,
john
Old Nov 13, 2003 | 04:41 PM
1/4master's Avatar
anybody? por favor!! ^^^
Old Nov 23, 2003 | 12:18 AM
Trans Am Kid's Avatar
you have to remove the pan, then filter, towards the back of the transmission is a round aluminum housing (1-2 accumulator body) that is held on with 3 bolts (1 is long). Remove that accumulator body, then the piston and blue spring and spring seat, under the spring set should be 0,1,2,or 3 washers, 0=stock firmness 1=crisp 2=firm 3=very firm (Race only or high stall). To adjust firmness remove or add washers. Hope this helps.
Old Nov 23, 2003 | 09:11 AM
1/4master's Avatar
thanks dude.
