FLP level4 and SS3800 in..got an SES!
After the SES tripped, I had no overdrive or converter lock-up.
Scanned it with EASE and it was PO757..2-3 shift solenoid stuck on.
What do you guys think, bad solenoid? Came unplugged? Any ideas? Is it in the valve body accessible by removing the pan?
Thanks.
I just erased the code and disabled it with edit, this should take care of it.
If that was me I'd rather try the shift solenoids first. 10seconds of work with a screw driver or pay $250 to have the stock verter put in and then again $250 to swap it back.
"Trust me I learned from experience and wasting a lot of money..."
So you want him to waste his money and then learn from experience too?
At least if it's not the shift solenoids then he isn't out $500. But if it's not the converter he is out $500.
Must be some sort of limp mode that the trans goes into, not something wrong with the solenoid.
How I wasted money was doing all what Mike from Yank said. I changed solenoids, raised line pressure and so forth. Nothing fixed the problem. That is speaking from experience. I am trying to help him to the resolve the problem. Why waste $250 on paying someone to swap the converters?? You could do it yourself. It isn't that hard, I did it using jack stands of my F-Body in 2 1/2 hours. He has a truck with a ton more room under it...
Never the less, I am not trying to get into a pissing contest with anyone. I would lie to know what you end up doing to resolve the problem. Keep us posted.
Been there done that after 14K mile of SY3500 abuse to my stock tranny. The 2-3 is the most common one to go. The same converter with an additional 18K miles in with the FLP Level 4 has never caused the code again.It's an annoying error that occurs when the solenoid fails to activate in a timely manner for the shift. Tranny does a lock out in some cases. The lockout may clear after the car sits off for about 10 minutes even though the code will still be there.
You can always clear the code and keep running it which I did for 2 months on my old tranny before we put in the new FLP Level 4. However, with money invested in the FLP now, I would get it swapped out and enjoy your new converter and tranny combo.
Rick
Rick
Where are they - external? Do you replace them with GM parts, or does someone make better ones?
