What could this be??
Old Jul 6, 2009 | 09:58 PM
BATA's Avatar
Default What could this be??
Ok a few months ago I had a stall converter installed (ptc 3600). The car goes throught all the gears fine and launches good also. However somtimes if im driving around 65mph the car seems like it automaticlly down shift. Also somtimes i'll be driving around the same speed (60-70) and when i go to speed up it seems like its wants to slip, or its stalling way beyond 3600! Does all the above sound like low trans fluid??
Old Jul 6, 2009 | 10:39 PM
performabuilt's Avatar
LS1Tech Sponsor
Have you been tuned for the stall and any ses lights on?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 7, 2009 | 11:28 AM
BATA's Avatar
No the car wasnt tuned for a stall because several people told me that I wouldnt need one for it and there arent any trans codes in it.
Old Jul 7, 2009 | 11:50 AM
LS1Tech Sponsor
For a 3600 stall you will almost always need tuning and some code test deleted . It sounds like you are dropping into limp mode which is a comon issue with a high stall and untuned 4l60e pcm
__________________
Call 888-744-6542
Old Jul 7, 2009 | 02:26 PM
BATA's Avatar
So what affect is this having on the trans if this is the case?
