can i use ANY 4l80e?
im hoping to pick one up at a junkyard or a trans shop
then worry about the verter
if its all its supposed to be,
i should have enough loot saved for an awesome rebuild by the time it gives
what will i need to make this work in a 96 Firebird with ls1?
a verter from Yank? can they make one?
a special flexplate?
a spacer?
i searched
i did!!
there is a tag on the side that tells the year
i paid $150 and $250 for a couple 2004 units(rebuilders) and passed up a newer one that was supposed to be good for $350, but remember these things are used in large trucks, so by the time they hit the junkyards, their in need of rebuilds
what would be the consequence of having < 97?
would i have to buy $50 extra parts? $200???
ill look for 97 and up
how much should a rebuild cost?
what do you think?
TransGo and transcooler and hope for the best?
where could i get a converter for this thing?
ive been reading about a special flexplate?
and a spacer?
arent spacers bad???
i want to get this one from a 97 "dually" for $325
does "97 and up" cut it?
or is there some way to identify it from looking at it from the outside?
i gotta get one asap and can't afford to buy the wrong one =\
thank you all
i havent confirmed what i actually bought
could be anything
i hope the 98 CU can control the 4L80e
i dont wanna have to manually control this thing
next step:
6.0L flexplate and bolts
may be the easy way out. Self contained pretty
much, little display and touch buttons.
If you want a stock PCM to run it, you need a
"segment swap" binary which will then be a kind
of nonstandard thing (beware a dealership reflash
or an alternate tuning software). Not to mention
the half-dozen variants of '98 OS to begin with.
