Help i lost 1st gear and Overdrive...
Old Aug 7, 2009 | 04:51 PM
mj114679's Avatar
Default Help i lost 1st gear and Overdrive...
ok i have a 1995 z28 camaro with 126k miles and and tranny built about 7k ago.... well my right transmission mount broke about 2 weeks ago, and i was babing the car till i had time to get it changed.... well today i drove from waco to houston and as soon as i got into houston i pulled away from a red light and i lost 1st gear and it was trying to take away in 3rd... i looked down at my speedo and it sits at zero.... i shifted down to 2nd and it shifted... then i went to 3rd and it shifted to 3rd then i went to OD and it stayed in 3rd.... can someone please help me out. i am now in houston and i have to work on sunday or i will lose my job.... i have no idea what went wrong... but the good news is my transmission is under warranty... if it is the tranny, then cool. but now i gotta find away to get it back to waco....\
Can anyone help me out???
Old Aug 7, 2009 | 04:57 PM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like you are just in limp mode. I would scan for codes first it is very likley only a minor issue you can handle where you are .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 7, 2009 | 05:03 PM
performabuilt2's Avatar
LS1Tech Sponsor
if the tranny mount broke it mayhave damged the plug or the wiring harness have thatchecked
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old Aug 7, 2009 | 05:05 PM
mj114679's Avatar
ok i talked to some people down here and they said it could be my speedo sensor... could that be right guys?
Old Aug 7, 2009 | 05:44 PM
LS1Tech Sponsor
Again your best be is to scan for codes instead of making guesses
__________________
Call 888-744-6542
Old Aug 7, 2009 | 05:58 PM
jimmyblue's Avatar
Moderator
Without speed sensor all PCM shifting logic is out the
window. 90% of the tables are MPH based. If you still
see zero MPH then get under there and check wiring
and connectors.
Fix the problem you know you have, and then see if
you have any left.
Old Aug 7, 2009 | 07:08 PM
mj114679's Avatar
its not throwing any codes... so why would i scan it? i am going to mess around with the speedo sensor tonight to see if its broke or unplugged. and replace it.
and please guys... just try to help me out... no need for the nonsense PLEASE.
Thanks again to the peeps trying to help
Old Aug 7, 2009 | 07:09 PM
mj114679's Avatar
and connectors.
you have any left.
OK thanks! will do.
i will keep this up to date. keep checking in and leaving comments
THANKS!!
Old Aug 7, 2009 | 07:12 PM
LS1Tech Sponsor
we are trying to help you with the transmission only have 3rd gear this means that the trans has no power with both solenoids off gives you 3rd gear with the solenoids having no power this will give you 3rd gear most likely the trans is unplugged could have happened when the mount broke if it hit the tunnel hard enough or it could have split the wiring harness which goes across the top of the tranny and could have gotten pinched between the tranny and the tunnel
__________________
Old Aug 7, 2009 | 08:01 PM
LS1Tech Sponsor
No NONSENSE How would you know that you dont have any codes without scanning it. I have scanned many a car with no check engine light that did indeed has codes.
As for the VSS is the speedometer working ?
However no VSS would be more likley to leave you with late shifts and or no shifts while starting in first gear not third. Check wiring and harness and plug also check fuses
__________________
Call 888-744-6542
Old Aug 7, 2009 | 08:20 PM
mj114679's Avatar
ok thanks! so i went out there and i checked the VSS (btw no my speedo is not working) and it seems fine. not broken or anything.
Ok so with me checking the harness and plug do i have to pull the tranny out?
can anyone give me a diagram where the harness goes and where the plug is?? Please
Old Aug 7, 2009 | 08:47 PM
LS1Tech Sponsor
the plug will be on the passenger side of the tranny directly bihind the servo it is grey to be honest if the speedo isnt working and the tranny only has third i think something happened to the harness
__________________
Old Aug 7, 2009 | 10:45 PM
mj114679's Avatar
ok thanks for beening honest. but now the tranny is suck in 1st....
i ahve no idea what it could be but i will check the plug and the harness. thanks guys. please keep the great ideas coming!
Old Aug 7, 2009 | 11:06 PM
LS1Tech Sponsor
if you are having some kind of electrical problemit is possible to be stuck in firstalso lets check the integrity of the tranny..unplug the tranny it should start in 3rd if it starts in first then you have a tranny problem if itstarts in 3rd then you have an electrical issue
__________________
Old Aug 8, 2009 | 12:30 AM
mj114679's Avatar
Ok. Let me get the right... unplug the tranny and start the car?... or unplug the tranny plug it back in then start the car?
Old Aug 8, 2009 | 09:57 AM
LS1Tech Sponsor
with the car off unplug and then replug in mthe harness, However you will remain stuck in first so long as the speedo is not working. I would replace the VSS
__________________
Call 888-744-6542
Old Aug 8, 2009 | 03:32 PM
mj114679's Avatar
Ok well I rented a car so I do have as much stress before. So I am taking it to my buddies shop. So I will first replace the vss. Then go from there. And btw my buddie is gunna scan the codes also
Old Aug 8, 2009 | 05:04 PM
01ssreda4's Avatar
this may sound dumb but did you check the fluid level? Mine started in 2nd and would only go to 3rd, no 4th, and it was about a quart or so low. I shut the car off topped it off and everything went back to normal. My speedo worked though.
Old Aug 9, 2009 | 07:19 PM
mj114679's Avatar
yes thats the first thing i checked.
i am in waco now and its in houston monday morning its going to the shop... i would figure it out but i got no time and i got no way to get it to waco.
Old Aug 14, 2009 | 12:40 PM
mj114679's Avatar
you were very right sir.
thanks for all the input and help guys now i am back on the streets!!!!
