Can't DD A RMVB?
Old Aug 14, 2009 | 04:10 PM
danhr's Avatar
Default Can't DD A RMVB?
I have done several searches, but have only seen this topic touched on, never gone in depth. So I figured I'd make a thread to get more details on this.
I read, in my quest for the right shifter, that you aren't suppose to downshift a RMVB, because it puts a constant load on the sprag. So what I'm gathering is that you can't DD a RMVB? I find this hard to believe because I know a few friends that DD their manual valve bodies. I want to DD my car during the summer months and what not, and I want to put a th400 in my car, and I know this means making sacrifices, but this seems a little extreme, even to my standards.
Can someone shed a little light on this topic please?
Old Aug 14, 2009 | 05:05 PM
tektrans's Avatar
I downshift my th350, no problems.
Old Aug 14, 2009 | 05:12 PM
danhr's Avatar
how many miles a year do u put on your car or is it pretty much track only?
Old Aug 14, 2009 | 05:13 PM
theblur98ss's Avatar
I didn't daily drive my T400 rmvb but it seen a good bit of street duty. I never did full throttle downshifts because I read the same stuff as you. The rmvb wasn't bad but the lack of overdrive was horrible. I ended up swapping to a 4l80e for this reason. The downside is that a 4l80e is probably at least double the price of a T400 for an initial install.
Old Aug 14, 2009 | 05:28 PM
danhr's Avatar
yeah... th400 is just temporary. I'm poor and will take me awhile to save up for the 4l80e. lol. plus i'm holding out for someone to make a rmvb (i think) and trans brake that work properly in the 4l80e
and I'm not taking any advice from you. I hear enough stories about you east brady type people and the water you guys drink. must be an upper allegheny thing......
Old Aug 14, 2009 | 06:00 PM
MDoe8's Avatar
You can dd a rmvb. Just have to rev the motor a bit above rpm match while downshifting. When coming to a stop, make sure you're in third gear. then once stopped, shift to first...off you go
Old Aug 14, 2009 | 06:26 PM
kenSS's Avatar
i put about 30 miles on my 350 turbo today with a RMVB. you can shift out of 3rd into second or first. just let off the gas and shift, it will free rev until back on the gas.
Old Aug 14, 2009 | 07:34 PM
MDoe8's Avatar
I believe your transmission is on borrowed time if you keep that up
Old Aug 14, 2009 | 07:49 PM
I think when rossler built my T400 he did a banded 2nd gear so I could downshift it. Does that make sense to anyone? When I would downshift it would seem like it was in neutral until I got back on the throttle.
Old Aug 14, 2009 | 08:06 PM
danhr's Avatar
I'm pretty sure with the coverage and as much as tektrans has been around the ls1 community, he knows what he's doing.
Old Aug 14, 2009 | 08:31 PM
1lejohn's Avatar
Years ago it was stated that you don't want to down shift an auto trans for engine braking. Why it puts a lot of wear on the crank thrust bearing, and generates heat in the trans. This was with old school gen 1 stuff. I still wouldn't do it today. I do down shift my trans from OD to 3rd or 3rd to 2nd when I'm about to hammer down on the throttle. This is usally at lower rpms. i do this because of the way 4l60s have a mind of their own. I also shift into od at the end of the 1/4 mile to take the stress off of the motor.
Old Aug 15, 2009 | 08:59 AM
darkhorsebob's Avatar
Thumbs up
TCI offers a reverse manual valve body with engine braking. Part number 221201.
Old Aug 15, 2009 | 10:51 AM
Jays_SSZ28's Avatar
The few things you need to consider are with downshifting mostly.
One problem, thats minor, and I've only seen it once came from a th400 with no front band. Every time the guy ran the 1/4 mile he'd put it in first to coast down. With no front band the direct drum over runs. In this peticular case it was slinging fluid off the intermediate sprag and it failed.
That guy got lucky, some people who drive at a high mph and throw it in first get the direct drum through the floorboard. It can explode.
As for daily driving it...I've seen threads on this were people are scared to death over bullshit.
If you have a RM th400 with no front band, just don't be stupid with it.
No high mph 0% throttle downshifting pretty much. If you're in the city driving under 70 mph and with limited distance, just get the manual shifts close to what they would be automatically, if they're not dead on so what.
Just don't get one with a roller clutch, and stop worrying.
Old Aug 15, 2009 | 04:36 PM
PowerShift408's Avatar
Rossler makes both a RMVB and trans brake for the 4l80e. I believe they have the patent on the trans brake for the 80e if I'm not mistaken.
Old Aug 15, 2009 | 04:41 PM
1lejohn's Avatar
Rossler rocks. So far their 4l60 has been the best one that I,ve used. You can also now get a 4L80 with a FMVB so no more $$$ computer to run it.This will be my next trans. That or a Liberty. LOL
Old Aug 15, 2009 | 04:47 PM
You don't need a computer to run it. You can get a $200 harness from Speartech and then a custom OS will need to be created through HPTuners and your stock computer will control it.
Old Aug 15, 2009 | 04:59 PM
WYATT318MOPAR's Avatar
Go with a forward patter manual setup, that is what I run in my 400. Has much softer downshifts below wide open to allow you to actually use it driving up hills and what not. Unless I am coming up the big *** hill to my house I seldom ever have to downshift anyways just lean on the skinny pedal.
