Switched to TYPE-F today
Old Nov 23, 2003 | 11:07 PM
Cheatin' Chad's Avatar
Default Switched to TYPE-F today
Decided to get a complete trans flush and switch to Type-F today.
Ran "Wynns trans cleaner" through for 10minutes then 10qts (trans holds 8.8 in case anyone cares) and finally "Wynn's high friction additive"
Trans put out 20-40psi at idle (depending on gear) during the process.
I used Castrol Type-F.It was the only name brand ATF in type-f avilable locally.
Will probably switch to Redline racing fluid when my new deep pan gets installed.
Shifts seem smoother if anything which I find odd.
Old Nov 24, 2003 | 12:50 AM
Colonel's Avatar
I question the "Wynns Trans Cleaner" and ESPECIALLY the "Wynn's High Friction Additive." These things, at the very least, are NOT necessary.
I can say with a great degree of certaintly that if you do a regular 'ole flush with nothin' but STRAIGHT F-type, you'll see better shifts. I had the flush place try to sell me their "tranny cleaner" and "shift improver" (which simply means that it'll shift SLOPPIER) when I went too. I stood right over them and made damn sure they only installed F-type fluid and nothing else. This STOCK frictions tranny with 27,000 miles has NEVER shifted better.
Old Nov 24, 2003 | 08:49 AM
LS1INSIDE's Avatar
yeah same here, I agree with colonel, i bought my own fluid and poured it in the machine myself, I didn't drive it that much after the flush which was a couple days ago but the following day i took it that car on a long trip and the car just feels so much crisper and "lighter" in a way for a 1.22 a qt couldn't be better.
Old Nov 24, 2003 | 04:44 PM
Ya know, I have been thinking about the additives since I had it done.From what I read here the only difference is the additives. So that would have to be why I am not getting results.Right?
I am using Castrol ATF and it claims smooth shifting on the back.
I put about 20miles on the car today and it's shifting slightly quicker but alot smoother.
I think I am going to get it redone without additives after I get the deep pan installed.
thanks
Old Nov 24, 2003 | 07:06 PM
2001 Pewter WS6's Avatar
Restricted User
Can you just drain the pan and change the filter then refill it with the Type-F? What brand to get? I see Autozone has their own brand.
Old Nov 24, 2003 | 08:38 PM
Colonel's Avatar
Just draining the pan doesn't come close to changing all of the fluid. The best way it to use a flushing type machine. It should take about 14 qts.
Old Nov 24, 2003 | 08:59 PM
Restricted User
I forgot that converter holds a good bit... I will take it to have it done.
Old Nov 27, 2003 | 09:25 PM
8.8qts total fluid capacity of the stock converter/4l60e.
That's according to the transmission flush machine reference manual.
I think you get 5 or 6 qts out on a pan drop.
Old Nov 28, 2003 | 02:33 AM
wicked LS1 Z28's Avatar
any particular type f fluid i should use? or are they all about the same ?
Old Nov 28, 2003 | 02:43 AM
Well, They all are supposed to follow the Type-F standard but I'd imagine there would be slight differences brand to brand.
Old Nov 30, 2003 | 04:23 PM
OK, I am now running straight NAPA Type-F and a TCI cast AL deep pan. Shifts are indeed firmer. WOT 2-3 causes the car to jerk forward where it used to just slip in. Shifting into 2nd under all conditions is similar to cold 1-2 shift when I was running DEX3.
