th350 setup
Old Aug 21, 2009 | 04:07 PM
txh0tb0i972's Avatar
Default th350 setup
ok i am very limited to "search" from my phone so dont break my arm. But Im lookingfor a long tailshaft 350 what yr car/truck do i get it from??? i want to use my stock drive shaft keep that in mind.. thanks!!
Old Aug 21, 2009 | 08:54 PM
Blue85350's Avatar
here, check this out.
http://www.thirdgen.org/techboard/fa...ngth-info.html
Old Aug 21, 2009 | 10:16 PM
Jays_SSZ28's Avatar
Not mentioned in the link. Don't get a th350C, usually in anything from 1981 to 1985.
To check just make sure it doesn't have a four pin electrical plug on the drivers side.
The problem you might find with a th350c is finding a high stall converter for cheap.
They can be converted to non lock up with a non lock up type pump, input, converter and some valve body modifications. Not worth the trouble if you could have found a regular th350.
Old Aug 22, 2009 | 10:02 AM
so would a th350 work from a 82 suburban
Old Aug 22, 2009 | 07:01 PM
racing1g's Avatar
Yep....as long as it's not a TH350C, they are just a turd to find a converter and shift kit for.
Old Aug 22, 2009 | 08:07 PM
jakeshoe's Avatar
I've got some long tail TH350 cores.
They came in a lot of GM large cars and trucks.
Old Aug 23, 2009 | 08:44 AM
pm me how much.....
Old Aug 23, 2009 | 11:41 AM
pm me how much.....
Old Aug 23, 2009 | 11:56 AM
nprather's Avatar
how much?
